Question about Dryers
ESTATE WHIRLPOOL TURN ON SHUTS OFF
MW3542369
    Top Expert:
  • Dryers Master
  • 9,472 Answers
That model number comes up as a microwave.
Posted on Dec 07, 2012
Starts to run then shuts down
How long does the dryer run before it shuts down?
Jan 05, 2014 | Whirlpool Estate EED4400WQ 6.5 Cu. Ft....
Estate Washer (top loader) by Whirlpool. Model Number: TAWS800JQ1 Water will not drain from machine after ten minutes through rinse cycle. It just stops (just shuts itself off) What do we do??
Most likely it is your pressure switch. Locate the switch on your machine and look for damage. if you have a multimeter use it to find any electrical issues if there is no reading the pressure switch needs to be replaced.
Jan 29, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
How do you replace the water inlet valve on the estate by whirlpool
You unplug the machine, turn off water and bleed off pressure, open the wahsing machine case, disconnect water hoses and electrical connections to the valve, and then unscrew the valve's mounting screws.
Oct 03, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate by whirlpool/agitator will not turn
under the top half of the agitator there are 4 agitator dogs. these pieces have edges to them that catch the inside of the upper agitator and if they are worn down, and they do wear, it will not move the agitator for you. hope this helps.
Oct 14, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Estate washer won't agitate or spin. Makes hum'g noise like motor on but won't turn. Last couple times i used it made a ticking noise but still worked fine. Then nothing. Any advice? =)
Did you just do a rug or a comforter in that washer? if so you may have broken the drive coupling. Check out these repair photos with manuals and vids.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool estate dryer stopped working mid-cycle and will not turn on at all now
The thermal fuse is bad . Located on the blower box , a small white piece , with 2 wires attached to it . Have to remove the front panel to access .
Aug 09, 2009 | Estate Dryers
Eleven year old Whirlpool electric dryer cannot turn the drum with a full load of towels. The motor turns on but then shuts off. It will turn a very light load.
Turn the drum by hand. It should rotate fairly easy in one direction. If so, then the motor is going out and need replacement. Fairly common problem.
Jul 13, 2009 | Estate TGDS840JQ Gas Dryer
ESTATE DRYER BY WHIRLPOOL TO SWITCH DOOR FROM LEFT TO RIGHT
Look in the whirlpool wedsite for you make and model and for spare parts list.
Jan 11, 2018 | Estate EED4300SQ Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Open Questions:
Dryers Logo
27 people viewed this question
Top Dryers Experts
