Question about Samsung Kitchen Ranges
The PCB assembly board keeps turning off. Reset by turning electricla power off for about 20 minutes. It then works again. Any one know the cause and cure?
The PCB assy. board keeps cutting out at odd times. Reset has been by turning off electrical power to range for about 20 minutes. Now this is not working at all. The stove's top elements continue to work.
    Top Expert:
  • Samsung Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 07, 2012
  • Veikko Autio Dec 07, 2012
    Model number is FCQ1HTUB
SOURCE: Stove elements won't turn off
replace switch for that burner
Posted on Jan 17, 2008
aborcass
  • 2651 Answers
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
SOURCE: Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Posted on Dec 24, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Spectra flat top stove electrical short
Go to your electric circuit panel. Locate the breaker for the stove. Turn it all the way OFF then back ON. This should correct your problem.
Posted on Aug 18, 2009
Testimonial: "Spot on advice. Thanks so much for the help!"
  • 35 Answers
SOURCE: Oven and elements do not function on an old electric range
check for 220 volt to range
Posted on Jan 02, 2010
Sharp LCD TV takes a long time to turn on
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 16, 2016 | Sharp Televison & Video
Hotpoint sdw60 dishwasher the delicate light keeps flashing
First try unplugging cable from power outlet for 15/20 minutes, to reset the appliance, so to ensure that is not the control board gone funny for a while. If this does not work it is likely that you need to replace control board.
Mar 30, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Error e197y
E197 0000 Printer engine communication error
Erroneous communication between the DC controller PCB and
image processor PCB was detected.
- Check the connectors of the DC controller PCB and image
processor PCB.
What I've seen is that code comes up occasionally and can be reset by turning the copier off and on again. Bad input power caused this. Check the power from the outlet and also check to see if you have a good ground. If your problem ends up being power.....call an electrician or plug it into another outlet that tests ok - do this before a board gets damaged and you end up with a code that cannot be reset and have to replace one or both of the boards mentioned above.
Jul 24, 2014 | Canon IR-1022 Copier
Pcb board
Possible causes:
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
SEE the steps before and fix it. God bless you
May 28, 2013 | Samsung Microwave Ovens
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Error e0610096 in canon 1140
The Service manual say:
E061 is an error code associated with the mechanism controlling the surface
potential of the drum, and points to the following:
(The notation "xx" of detail code indicates the color of the developing
assembly; e.g., xx=01: M, xx=02: Y, xx=03: Y, xx=04: Bk.)
Detail code: 0096
Description: Vd2 is 550 V or less.
Possible cause: The Vd2 lower limit is reached
Step 1
Checks: Is the setting of
COPIER>ADJUST>V-CONT-M/C/
Y/K in service mode identical to the
settings recorded on the service label?
Yes/No: NO
Action: Enter the settings from
the service label newly.
Step 2
Check the detail code in service
mode (COPIER>DISPLAY>ERR).
Is it 0000 or 0001? YES Go to step 3.
Is it 0010? YES Go to step 4.
Is it 0020? YES Go to step 5.
Is it 0030, 0031, or 0032? YES Go to step 9.
Is it 0040? YES Go to step 12.
Is it 0050, 0051, 0052, or 0053? YES Go to step 16.
Is it 0070, 0071, xx80, or xx81? YES Go to step 19.
Is it 0060 or 009x? YES Go to step 20.
Step 3: Potential sensor unit
Checks:
Turn on and off the power switch.
Does LED1 on the potential
measurement PCB remain on
during potential control?
NO - Replace the potential sensor unit.
YES - Check the wiring from the
DC driver PC to the potential
sensor. Turn off and then on
the power switch; if the error
is indicated once again, go to
step 2.
Step 4: Pre-exposure lamp
Checks:
Does the pre-exposure lamp turn
on during copying operation?
NO - Check the wiring from
the DC driver PCB to
the pre-exposure lamp;
if normal, replace the
pre-exposure lamp.
YES - Check the potential
sensor unit. Turn off and
then on the power switch;
if the error is indicated
once again, go to step 2.
Step 5: Primary charging assembly
Is the primary charging assembly
connected properly?
NO - Connect the assembly
properly.
Step 6: Primary charging assembly
Is the primary charging wire
broken or soiled?
YES - Clean or route the charging
wire once again. Turn off and
then on the power switch; if
the error is indicated once
Step 7: Primary charging assembly
Are there traces of leakage on the
primary charging assembly?
YES - Replace the primary
charging assembly.
Step 8: High-voltage cable
Is there electrical conductivity
from the primary charging wire to
the high-voltage transformer
(HVT-DC)?
NO - Check the primary highvoltage
cable.
YES - Replace the HVT-DC
PCB. Turn off and then
Step 9: HVT-DC PCB
fitted properly?
NO - Fit the assembly
properly.
Step 10: Primary charging grid plate
Is the grid plate of the primary
charging assembly mounted
properly?
NO - Mount the grid plate
properly.
Step 11: High-voltage cable HVT-DC PCB
Is there electrical continuity from
charging assembly to the highvoltage
transformer (HVT-DC)?
NO - Check the grid highvoltage
cable.
Step 12: Post-cleaning charging assembly
Is the post-cleaning charging
assembly fitted properly?
properly.
Step 13: Post-cleaning charging assembly
Is the post-cleaning charging wire
broken or soiled?
YES - Clean or fit the charging
wire properly.
Step 14: Post-cleaning charging assembly
Are there traces of leakage in the
post-cleaning charging assembly?
YES - Replace the postcleaning
charging
assembly.
Step 15: High-voltage cable
assembly to the high-voltage
NO - Check the post-cleaning
high-voltage cable.
Step 16: Laser exposure system
Is the movement of the laser shutter
normal?
NO - Check the shutter
assembly
Step 17: Laser exposure system
Is the dust-proofing glass or the
bending mirror soiled?
YES - Clean it.
Step 18: Laser exposure system
Is the laser power normal? (See the
descriptions given for how to adjust
the laser power.)
NO - Adjust the laser power.
If output is absent,
replace the laser unit or
the laser driver.
YES - Check the
photosensitive drum for
grounding; if normal,
replace the
photosensitive drum.
(After replacement,
execute the work under
II. C. 2.)
Turn off and then on the
Jan 13, 2011 | Canon CLC 1140 Copier
Ge refrigerator
HI. This will be the cause of a defective PCB. This circuit board is the main controller of your unit. the clicking is the result of a failed relay assembly. these relays are mounted on the board, itself. The board should be mounted just behind an access panel, on the rear of the unit, slightly above or near the compressor assembly. Kindly have this PCB replaced, asap.
The PCB is , indeed, the culprit in this situation. Once the PCB is exposed, you should visually inspect for brownish discoloring, and relay trauma. Possible power surge may have caused the board to short.
Feb 01, 2010 | GE Profile Stainless Bottom-Freezer...
Question?
it has to be the power supply board..contact ur service centre and tell them ur problem...if its under warranty,GREAT! but eitherwise u will have to ask them to replace the board.
Thanks for using Fixya
and plz do update me
Jul 17, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Kitchen Ranges Logo
458 people viewed this question
Top Samsung Kitchen Ranges Experts
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
