Question about Hayward H-series Electronic Gas Pool Heater H400
My H series pool heater won't adjust the temp up, only down. Is the control bad?
    Top Expert:
  • Hayward Master
  • 5,061 Answers
Bad display control board
Posted on Oct 01, 2017
  • 139 Answers
SOURCE: MY HYWOOD h SERIES POOL HEATER DOES NOT LIGHT. IT
are you sure the code isnt FO , which would indicate flame sensor failure.usually can be solved by removing and cleaning fl sensor with fine emory cloth.since htr is calling for heat ,pressure switch does not need adjusting
Posted on Jul 23, 2009
  • 366 Answers
SOURCE: Heater ignites in spa mode but not pool mode
Sounds like you may have a bad temperature sensor. Check for damaged wires or have a technician test the sensors. they should have a certain resistance property, if they are not within the set parameters the sensor will not allow the heater to fire. If there is a separate thermostat for the pool side, check that as well.
Posted on Sep 15, 2009
  • 990 Answers
SOURCE: I can't turn off the unit without shutting off the
You are probally having a problem with your pressure switch in the heater. This is located in the cabnet on the left side about half wau up just above the burner tray. It will have a ferrel nut on the back you can unscrew to get it off the copper tube it is attached to. Do this with the breaker off and once it is removed from the tube start the pump for a second and see if you have a freeflo of water from tube. If you do you need to ck the pre sw by replaceing the unit on the tube and removing one of the wires to it. If this solves the problem you probally need to replace the switch. If you don't get water flo through the tube you will need to follow the tube to where it hooks to the manifold and remove it there and clear the hole it goes into and the tube it self. This is a rare occurence on these heaters as they have plastic headers. My bet is you will find the pressure switch has gone bad. Good lucl I hope this has helped.
Posted on Dec 02, 2009
jharwell668
  • 640 Answers
SOURCE: hayward pool heater h series
It could be that your gas connection has a blockage that is preventing adequate fuel for from getting to the heater. If that is not the case, try consulting your owners manual for these pool heaters. There is an online copy at the link below.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
adamh294
  • 310 Answers
SOURCE: I have a haywood h
Allheaters run off of a thermostat just like the heat to your house. It will shut off once heated to the selected temperature. Turn up the temperature, and monitor it for a couple days.
Posted on Dec 29, 2010
HEATER WON'T INCREASE TEMP
if display wont go up or down bad display
Mar 25, 2013 | Sta Rite Pool & Spa
I have an h250 heater for in ground pool. When I set the temp it ignites for about 5 seconds then shuts off???
That brief delay is likely the window allowed to heat the thermocouple and it is probably defective. After that delay expires, it shuts down for safety to avoid unlit gas from escaping. If the TC is bad, the controller doesn't know if the gas flame ignited or not.
May 27, 2011 | Hayward H Series Electronic Ignition...
I have a haywood h series h 400 pool heater. Each night the the pool pump timer runs b/t 12-7am.. The heater was working fine. and pool temp is around 70-80.. However, lately the heater which is on when...
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
H-series Electronic Gas Pool Heater H400: I have an H400 with digital temp control panel, th...
It is likely the keypad that has gone bad. Not difficult to replace. But you want to be sure thats what it is, as it is an electronic part, that is usually not returnable. The part number would depend on the model of the heater. Likely it is a h400idxl2 heater.
May 16, 2010 | Hayward H-series Electronic Gas Pool...
HAyward H series gas heater 2500i
There is a thermistor temperature sensor beside the inlet union on the heater that goes bad, it looks line a stainless steel nut with wires on it. You can unthread to replace it and it plugs into the board behind the display. The LO means low pressure probably caused by pressure switch adjustment.
Jul 07, 2009 | Hayward Pool Products Hayward 200k Ng H...
Hayward H-series Electronic Gas Pool Heater H400 Logo
107 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
