Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Thin twin tub loose
The tub shakes violently and bangs into the cabinet. What has broken and is it hard or expensive to repair?
  • Vin Marino Dec 08, 2012
    That's it Dan. All 3 are disconnected from the cups at the bottom. Can I just push them back in or do I need to replace them? There is only one spring holding the tub to the base.
  • daniel  hendrickson
    daniel hendrickson Dec 08, 2012
    try re connecting them first then run a load and see if they stay connected,if not they probably have lost their spring tension and need replacement,try this first its the low cost way,why buy if you dont need to......thanks.... Vin.....regards
    President:
  • Whirlpool Master
  • 1,922 Answers
You will need to remove the front panel of the washer,there are 3 spring suspension rods below the tub and either one or more of these springs are disconnected from the tub or broken
Posted on Dec 07, 2012
5 Suggested Answers
  • 298 Answers
SOURCE: tub shakes violently even running just water on
maybe the belt
Posted on Dec 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: Drum inside washing machine seems
Might be a spring or the skate plate out of alignment.
Thin twin service manual is in this apartment series service manual:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZDgzODI5MjYtMWNmYS00MWZkLTk0ODEtNjM3MTIyYzVmZWVl&hl=en
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 20, 2011
IFIXALL
  • 868 Answers
SOURCE: thin twin
on this  problem one of 2  the Shocks have pulled a part (seperated),possibly even broke off.After removing the front panel ,you'll see that on each side towards the rear of machine you have a shock ( similar to a car) arm starting from the base and angling upward where it meets the tup.Look for the seperation there and then let me know and I'll be happy to guide you through this.
Posted on May 28, 2008
ned_san_jose
  • 234 Answers
SOURCE: Whirlpool heavy duty thin twin broken heater, the
Hi, thanks for the inquiry.
If it's a gas dryer, it's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
If it's an electric, it's either the heating element or the thermal cut-off, most of the time.
You'll proabably have to get to the element and fuse from the back. What I would do is just tilt the entire unit forward, if it's in a tight closet.
Best of luck and please feel free to contact me if you have any questions.
Ned
Posted on Sep 21, 2009
What causes the thin twin washing machine to shake violently?
out of balance is the main reason for shaking machines
out of balance can be poor distribution of the wash or the tub and machine is not level
Dec 20, 2016 | Washing Machines
Could the spinning barrel be off center,what has come off?
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Mar 19, 2015 | Washing Machines
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
Bang noise on left side of cabinet on spin
you have a broken tub spring,you can repair this by taking the back off or laying it down and locating the broken spring and replacing it refer to youtube they have a lot of videos showing the process.hope this helped
May 19, 2014 | Maytag MHWC7500YW 24" Front-Load Compact...
Drum inside washing machine seems to come loose..making a really loud banging noise. Whats the best way to fix this.. Whirlpool Thin Twin
Sep 18, 2011 | Whirlpool LTE5243D Top Load Stacked...
I havea whirlpool duet when the tub spins it makes a banging noise
hi sound like the tub support on the back of the tub have broken and that a costly repair.if the washer is less thin 5 years old may still be under warranty
Oct 22, 2010 | Whirlpool Washing Machines
Our sport duet washer shakes violently even thou it is level
Under neith the tub is a series of shock absorbers like on a car, from time to time these come loose or fail. I have a duet repair manual:HERE
Jan 24, 2010 | Washing Machines
On high spin the drum bangs against the rear inside walls of the cabinet. Dents are noticable from where it violently shakes.
There is usualy a switch located under the agitator that senses when the machine is spinning off balance. What are you drying? But it sounds like a bad off-balance switch.
Dec 16, 2009 | GE Washing Machines
The tub is offline and shake the washer violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 12, 2009 | Kenmore Washing Machines
Kenmore he2 washer shakes violently
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
1,134 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
