Question about Dell UltraSharp E248WFP 24" LCD Monitor
Verticle lines/streaks down screen
I have multiple verticle lines/streaks down the monitor's LCD screen. These lines don't appear when another monitor is attached so it's not the video card. I also tried hooking the monitor up to a different computer and same problem with both VGA and DVI hookup. I tried looking at all the capacitors but I couldn't visibly see any that looked like they were bulging or leaking. The lines don't move and seem to be of multiple colors. I can't see them along white or black background colors. How do I go about fixing this?? Thanks for any suggestions!
    Top Expert:
  • Dell Master
  • 14,553 Answers
The Display panel could be bad/damaged or the main board that controls every thing could be bad---parts for Dell equipment are known to be hard and sometimes impossible to find.
Posted on Dec 07, 2012
3 Suggested Answers
  • 73 Answers
SOURCE: Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Posted on Jul 24, 2009
  • 3940 Answers
SOURCE: Dell 2005FPW displays streaking vertical lines
The only way to repair this would be to have the LCD screen replaced in the monitor and more than likely you can buy a replacement monitor that is bigger for less than the cost of the LCD repair.
http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=6198&cs=04&l=en&s=bsd&~ck=anav&nf=7382~0~38115&sort=price
Posted on Dec 21, 2009
Hi in house expert,had a 14 inch sharp tv with a verticle line I change the transistor AN5522 and the 25v 1000 uf capasitor but verticle line still there,it could be what guys?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 21, 2016 | Sharp Televison & Video
Hello sir my samsung lcd monitor model no 740N . in dis monitor right side display two verticle lines green n light pink but hoe to i resolved dis problem please give me suggestion
You cant resolve it tiny resistors in the screen have failed and that is why the lines have appeared, it is a case of live with it or buy a new monitor
Feb 24, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
May 05, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
What can cause a single red line to appear on my laptop LCD screen? It's a small/fine red line appear horizontally (left to right) It's NOT radio interference,back light,broken ribbon cable,or connector...
Thats a generic problem with LCD screens. Its more common in Mobile screens. Sorry, no there is no fix to it other than replacing the LCD itself. Just pray that it shall not grow because as and when the compressed gas from within the LCD will leak the line will be becoming broader and broader. It is caused by damage to the LCD corner Just a hit on side of LCD and a hairline crack for giving way to the encapsulated gas.
Jul 28, 2009 | Computers & Internet
Verticle lines on monitor
Hi...there,
Well... I hate to say, but you got a damaged panel. Thinking of replaced the panel... you can forget it.
Get a new one...it's will saved you the headached and $$$... Have a nice day!
Oct 02, 2008 | IBM ThinkVision L170 17" LCD Monitor
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
Laptop lcd screen
that's not a firmware issue..your lcd is starting a slow decay to final unhappiness..
you can try the old driver downloader trick, but it's just a matter of time now.
Feb 21, 2008 | LG Flatron L1750S 17" LCD Monitor
Dell UltraSharp E248WFP 24" LCD Monitor Logo
206 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
