Question about Kitchen Ranges
How to take the top off LG gas stove
Just want to take the top off to get to the inside of the knobs
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 07, 2012
  • rod1153
    rod1153 Dec 07, 2012
    LGR3095ST
5 Suggested Answers
  • 78 Answers
SOURCE: gas ignitor
Try pulling the knobs out just a bit. sounds like one is jammed.
Posted on Dec 30, 2008
  • 833 Answers
SOURCE: tried to clean top of jenn air stove
If this is a gas stove, you've shorted out the ignitor circuit.  If it is electric...you may have gotten some of your cleaner into one of the controls.  See what doesn't work and trace from there.
Posted on Dec 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: scrubbed the gas fixtures on stove top, won't light
this is something I do not recommend you do yourseelf, but there is a adjustment screw on the front under the panel near the knobs little screw that can be adjusted
Posted on Feb 07, 2009
  • 10865 Answers
SOURCE: Maytag Gemini gas stove top ... while starting one
You have a gas leak which resulted in the unwanted fire. This has the potential to be serious or deadly. This is one time when you need to get a pro in there to stop this leak and get your stove safe again.
Posted on Jun 16, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Knob replacement AEZ72909002 for LG Stove
I'm way too late with an answer here, but I'll add it anyway in case someone finds this page later on. The AEZ72909002 part is not for the LRG30355/LRG30357 series of LG gas ranges, but for the LRG 3095/3097 series. The only explanation I can imagine for LG reversing the knob insertion profile, is to force their LRG30355/30357 customers into expensive repeated replacements.
Jan 17, 2012 | LG LRG30355 Gas Range
I have an stainless LG gas range and the knobs are loose and crinkled. LG will not replace them even though it is within the 1 year warranty period. They want to sell me a set for several hundred dollars....
I have the same problem. I have gone thru 2 sets of knobs for my LG Gas Stove. Even when I put JB Weld inside the knob to hold it together the knobs only last for 7-8 months of use. I am looking for a universal know with the same stem configuration to slip onto the shaft of the LG stove. It looks like a D
Jun 11, 2010 | LG LRG30855ST Stainless Steel Gas Range
Tried to clean top of jenn air stove
Dec 14, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
