Question about LG banter Touch Un510 U.S. Cellular
How can I turn on wifi to get on the internet?
I can not connect to the internet with my zeepad. I bought both of my daughters the same model tablet and they can get on the internet with their tablets.
Most tablets connect to the internet through WIFI. Only a few can use SIM card to connect through 3G or 4G data connection. For WIFI connection, you must have a WIFI router at home. You will normally password-protect the WIFI rounter. To connect the tablet to the internet through the WIFI-router that is in operation, you will configure its WIFI settings to match the router's password. This will be done by going to tablet's Setting, turn on WIFI, click on your router in the list of detected routers, enter the password when prompted. Ensure that Connected is shown against your router. You can then browse the internet.
Jan 10, 2015 | Tablets & eReaders
How do I access the WiFi Internet Connection With Tablet
to get access to the wifi network, you need to do the following things:-
1. go to settings
2. open wifi option
3. turn on wifi
4. select the wifi network you want to connect.
5.it will ask for the password, insert the password and enjoy.
Hope you get your problem solved. Thanks
Dec 15, 2014 | Samsung Galaxy Tab 3 7-inch, white
My nokia 2680's-2 phone can't connect to internet.
Via WIFI or data connection, if WIFI check security key is in put correctly, turn off phone and WIFI unit, wait a couple of minutes and try again
Apr 15, 2014 | Nokia Cell Phones
My Extreme 7" internet tablet does not open wifi function. Everything has been fine till now. Wifi button moves to yes and is blue but the sistem acts as though it was off. Does not scan for wifi or even...
Did you flashing the new rom for your tablet? if so then you could restore with 'factory rom'. Otherwise please restart your tablet, turn off the wifi function then turn it on again. Hope it helps.
Nov 04, 2013 | Mach Speed Trio Droid 2GB Internet Tablet...
I am connected to internet but cant get into internet
Try resetting the wifi connection and ensure that the source of the wifi is functioning properly, you may need to input the wifi password again for ensured connection.
Apr 01, 2013 | Adreno Graphics Neocore
I've used the internet but do not have free access, I know have a small blue icon at top of screen which looks like a 'blue dot with signal lines coming from it, which I cannot get to go away?! please...
Looks like your wifi is on and is set to the default internet option. Turn off the wifi first by going to the wifi icon in your menu and tapping the wifi circle in the middle.
To change the internet profile i.e. 3G go to menu/internet/settings/internet profiles and choose your preffered option, normally you will need to request internet settings from your network provider by sending a text.
The blue icon you speak of is tells you wifi is on this should go away once wifi is deactivated better to do this as wifi eats up the battery on this phone big time.
Mar 21, 2011 | Samsung Jet S8000 Cell Phone
Here?s the overview: My only computer is a laptop. I had Comcast internet connected to a Linksys wireless router; I cancelled Comcast and bought an AT&T 3G Sierra Wireless card. There?s an HP...
Generally all laptops with wireless built in have a shutoff button for the wifi connection. While you need the internet turn the wifi off. When you need to print, turn the wifi on, print then turn it off. It is not the best solution, but it should be a short term work-around. The other option is to attach the printer to your laptop with a cable (usb or otherwise). Turn the wifi off. Add more info to your request if this does not solve your problem,
If it solves the problem, leave feedback please.
Feb 10, 2010 | Computers & Internet
Wifi is not working and green wifi light is off
Hi there. Try to go under the BIOS settings, and check if wireless or wifi card is enabled. Good luck.
Mar 30, 2009 | Sony VAIO Notebook
Internet on iphone 3g??
Simply go to Settings > Wifi. If Wifi is off, turn it on. You'll see a list of available networks when you're in a hotspot. You can also have iphone tell you when you're near hotspots by turning on "Ask to Join Networks." You won't be able to use the internet when you're not in a wifi hotspot.
Oct 28, 2008 | Apple iPhone 3G
LG banter Touch Un510 U.S. Cellular Logo
23 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
