Question about Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone
How do you replace the control circut board?
Fridge not cooling. purchased control board but 1) not sure where the original is located 2) once located, how do I replace it?
    Top Expert:
  • Samsung Master
  • 9,472 Answers
It is located on the back of the unit.
Posted on Dec 07, 2012
2 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: model rb215lash bottom freezer not staying cool
is the condensor fan operating back in the lower area by the compressor,if not the compressor will cycle from heat and you will have fluctuating temps
Posted on Sep 01, 2012
Fridge Won't Cool
First off that "condenser fan motor" needs to be replaced. It is not running near the speed it needs to. (I replace those all the time on the job) Here is the replacement to order.Also, based on the information you provided, it sounds like the main control board is sticking in defrost and you will need to replace the main control board on the unit. GE has an updated control board that address's this problem along with some other issues the original control board had.Here is the updated board to order.
All the parts come with a 365 day, any part, any reason return.
Keep me posted!
Nov 01, 2012 | Refrigerators
Only lights and water dispenser are working on Maytag MSD2756DEW
overload switch for sure,stops the fridge once you replace that,if it doesnt defrost change the bi-metal
Jul 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Control board clicks every 3 sec. No cooling. No fan or compressor running.
Avanb, I can almost assure you that the control board is the problem. I'm assuming that the interior lights are on, but no fans and the compressor is not running. To make sure, first unplug the temperature control harness. (encoder). If the refrigerator starts running, replace the temperature control board (encoder board. If it doesn't start running, replace the main board in back. To remove the control panel, remove the 2 screws located on the bottom. Slide the panel down. Then just disconnect the harness to the temperature control. Catriver.
Aug 03, 2007 | Hotpoint HSS25GFP Side by Side...
Model rb215lash bottom freezer not staying cool
Aug 31, 2012 | Samsung RB215LASH
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
My fridge is about 6yrs old, and it just stopped getting cold, it runs but just not get cold. The fridge and freezer does not get cold. help!!
You should have it serviced at least once a year. Any way since it is 6 yrs old please get the cooling gas checked up. Quite possible that cooling gas has leaked out over a period of time.Also get the thermostat switch checked. It may be also not functioning properly. Check the settings of the thermostat. It should be set on the cooling side.
Oct 04, 2010 | GE Refrigerators
LFC23760SW is DEFECTIVE! Woke up to a dark fridge that didn't work. Paid $100 to find out it's a fuse. Apparently this is the same issue for ALOT of other people I've seen posting on the internet. ...
Ours went after 15 months. LG didn't want to hear about it.
Replace fuse and two weeks later the fridge stopped cooling (though freezer still works).
Complete sham. Sorry to say, but all looks, no performance. Garbage company with garbage 1/2 a$$ed products from phones to fridges.
Jan 03, 2010 | LG LFC23760SW Side by Side Bottom Freezer...
Refrigerator side will not cool on Frigidair Model FRS26ZGEW3
2 things could be the problem.. 1 check to see if the fan located on the temp. setting control assembly is working. If this fan is not on the fridge will not cool. if the fan isn't working replace it and problem should be taken care of. If fan is working then your defroster is out.. You can tell if defroster is out due to the big chunk of ice in space between the fridge and freezer where the fan is also located. Parts can be purchased at an appliance parts houseand aren't that hard to install. Good Luck
Dave
Jul 16, 2009 | Refrigerators
Frozen coils in freezer side of fridge/ freezer s/s
had the same problem with mine. found out it was the defroster timer circut board. mine was located in the reffidgerator side underneath the panel where the slide controls are. went to parts store and bought a new one for $35.00. it unplugs and plugs in easy. found out it's a commen problem and happens every couple years or so.
May 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone Logo
259 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
