Question about Sony CDX-GT540UI - CD/MP3 Receiver
Sony Car Stereo CDX GT540UI Buttons Unresponsive
My car radio randomly stopped working when I went to start my car one day. This problem has happened twice before, but I was able to correct it by holding down a few buttons. I can't seem to correct the issue this time though. The buttons on the face plate are completely unresponsive unless I quickly press the eject button once I start the car or take off the face plate and put it back on. When I do this I am able to cycle through the different sources by pressing the eject button, or I can control the volume by holding down the eject button and turning the volume nob. Also, pressing the eject button once will turn the radio off. I have read over the user manual for solutions, and have also tried pressing the reset button as well as holding down the reset button for ten seconds with no results.
  • JL Vega
    JL Vega Oct 11, 2013
    Hi. I have exactly the same problem and the stereo have the same behavior when tak the faceplate off. Do you find a solution?
  • Patrick Berger Oct 21, 2013
    I never was able to find a solution for the problem and
    ended up having to buy a new stereo.
    From other forums that I've read, it sounds like there is a harness
    adapter needed to hook up new stereos to certain cars that have OnStar ability
    even if they do not use OnStar. There is
    a work around to get the radio to work without the adapter, but my guess is
    that if you install the new stereo without the adapter the stereo will
    eventually begin to have problems and fail.
    Here's a link to a forum which discusses the issue, http://www.automotiveforums.com/t917161-....
  • 6771 Answers
SOURCE: My buttons on the stereo will not work. the only button that is working is the source button. I do not know what happen nor how to fix this issue. It's very annoying. I just bought the stereo last
If the stereo is less than one year old return it for repair or exchange.
Posted on May 31, 2012
MrLard
  • 94 Answers
SOURCE: Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Posted on May 04, 2007
  • 2039 Answers
SOURCE: Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Posted on Jan 14, 2008
ngfam1
  • 639 Answers
SOURCE: Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Posted on Aug 28, 2008
SOURCE: STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
Aug 28, 2012 | Sony XPLOD CDX-GT200 CD Player
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
I have a sony mp3 xplod car radio, buttons wont work on it to operate probaly, any suggentions as to what is wrong?
I had the same problem with my sony CDX-GT540UI and solved it! I just kept clicking the "source/off" button when the display was showing the demo and suddenly it started switching to USB/CD/AUX etc. This means that the contacts inside the micro-switch were stuck in the down position, continuously making contact, and blocking the signals from the other buttons. Have to replace the micro-switch now.
Dec 29, 2011 | Sony XPlod CD Player w/MP3 Playback...
Sony cdx-M8800 car stereo buttons wont work
There is a ribbon cable that runs all the flip panels electrics, these are prone to breakage.
I have seen some of the cables on e-bay for a few quid, and also if you google "sony x-pod ribbon cable" you will get a big choice of places to order, and get instructions on fitting.
Aug 25, 2009 | Car Audio & Video
Need security code for my sony cdx-m8800
Sony CDXM8800 Radio Codes are available from the website - www.instant-radio-code.co.uk
Aug 07, 2009 | Sony CDX-M8800 CD Player
CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
Jan 13, 2008 | Sony CDX-L400X CD Player
Dec 14, 2006 | Sony CDX-CA900X CD Player
Sony CDX-GT540UI - CD/MP3 Receiver Logo
541 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
