Question about Ovens
Unable to remove the glass cover to change the light bulb in oven
The bulb in the oven has blown but we are unable to remove the glass cover
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Posted on Feb 28, 2010
  • Ovens Master
  • 3,463 Answers
Switch power off first, get a pair of pliers or grips and wrap a cloth round the jaws of same, then grip the bulb cover with the grips and try to unscrew it that way, do not put too much pressure on glass, as you may break it.
Plz rate my solution.
Posted on Jan 12, 2009
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Aug 23, 2015 | Stoves Premier 720EMa Electric Double Oven
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Apr 15, 2015 | AEG Ovens
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Replace light
The instructions state:
1. Ensure the oven is disconnected from the electrical supply.
2. Turn the glass cover anticlockwise.
3. Remove the faulty bulb and replace with the new one.
4. Refit the glass cover.
5. Reconnect to the electrical supply.
Jan 09, 2014 | Zanussi ZBF360 Electric Single Oven
Unable to remove blown Blanco oven light bulb-stuck fast
I boiled the kettle, added the hot water to a tray and placed it in the oven, shut the door then left it for 10 minutes so it steams up the oven (make sure power is off first). Do the same again. Then get a multi grip spanner and place a kitchen rag over the cover and turn to the left. It does take a bit of force depending on how stiff it is, but the steam will loosen the cover. The steam also cleans the oven quite a bit too!!
Mar 04, 2013 | Blanco Ovens
I have a siemens electric oven. The bulb has blown and is encased in a glass cover. The intructions say to turn anti-clockwise to remove the cover, but it just won't budge. Ant ideas how I may free it?
The bulb cover is probably gummed up with solidified oven grease and therefore stuck.
The only thing you can try is to turn the power off and spray around the edge of the glass with oven cleaner and leave for a couple of hours in the hope that it will soften and allow you to unscrew it.
Be careful not to get the spray cleaner on to the heating elements.
Dec 17, 2010 | Ovens
Hi, I have a Neff oven Model No B144 2N0GB. The light has blown but I am unable to remove the glass cover to replace the bulb. It appears as if the glass cover has fused into its surround because it...
If the unit is less than two years old, cal 0844 892 8999 and ask for an engineer to come out. Alternatively, put on a pair of marigolds, this will help with the grip and remember that the cover comes of anti-clockwise if you are looking up at it. If you do not want to call an engineer out, call the number above and ask them to post out to you the lamp cover removal tool. Part number 613655.
All the best
Sep 01, 2010 | Neff B1644 Electric Single Oven
Trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
Nov 17, 2008 | Neff U1461 Double circotherm plus Electric...
Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
Ovens Logo
1,644 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
