ASUS Mouse left click not working
I've been using my mouse for less than four months now, and it's the mouse that came with my computer. I play Minecraft, so of course the left-click button is vital. Well, starting about a month ago, the left-click button has begun to wear down. I've seen different solutions to this problem on other mice, that include unscrewing the mouse, but mine doesn't have a screw. :/
yooperbud
  • 8637 Answers
SOURCE: Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
Posted on Jan 16, 2009
  • 24 Answers
SOURCE: Want to open and clean Intellimouse w/ sticky left click button
there's 4 sliders on the bottom of the mouse. Remove the 2 feet closest to the optical sensor on the bottom. You'll find 2 phillips screws there. Remove those then pry the mouse open.
Posted on Apr 17, 2009
  • 20 Answers
SOURCE: My swissgear, red, remote mouse won't work
Try to put a new battery in it's compartment and simultaneously press the reset small button in the bottom of mouse. Both actions mus be performed at the same time. Hope this might solve your problem.
Chawah.
Posted on May 05, 2009
SOURCE: Unresponsive left mouse click
I have that issue too. At the beginning I tought it was a connectivity problem but it does it even with the receiver side by side. Latelly it is working perfectly.
Posted on Jul 04, 2009
SOURCE: PROBLEMS WITH MOUSE
FIXED, I managed to fix my copperhead last night after its been sat under my desk for the past 4 months with doubleclick problem. I peeled off the lower slider foot, removed the QC sticker off the screw, removed the screw and took the top off the mouse. inside, under the faulty button (left mouse button for me) there is a little black box with a small thin white button on top. i very carefully lifted the black box slightly off its connection with a small flathead screwdriver then pushed it back down again. i did this with the mouse plugged in to usb blue lights on and everything. it stopped double clicking instantly, hope this works for anyone else. let me know.
I can now use my razer again. wooooooooooooooooo
Posted on Nov 13, 2009
Gateway Laptop with windows 8. Mouse pointer gone and won't come back
See if the mouse pad has been accidentally turned off. This can be done via the "Function" button on your Gateway laptop. To enable your mouse clicker again on your Gateway, head on over to the "Control Menu" in Windows and double-click on the "Control Panel" icon. Click on the "Mouse" option under the "Printers and Other Hardwareicon1.png" tab. In the next menu that pops up, click on the tab listed as "Device Settings." From this menu, you should be able to locate a listing for the mouse pad on your Gateway laptop. Click on this listing. From here, you should be able to enable the mouse again. Click "OK."
  • Head over to the official Gateway site online (see Resources). The above enabling of the mouse device under "Device Settings" may not have worked. Make your way to the "Software and Drivers" area of the site.
  • Check over your Gateway manual and find your specific serial number for your machine. Enter the number into the Gateway site when prompted and check to see if any driver updates exist for your mouse on your machine. If so, click to download the update, and then double-click the file on your computericon1.png to install it. Restart your Gateway laptop to have the changes take place. Your mouse should now work.
  • Jan 26, 2013 | Gateway Ne56r34u 15.6inch Laptop Black
    My Asus Q500A-BHI5N01 touchpad won't let me scroll with the two finger gesture. The mouse works fine, but the touchpad isn't nearly as responsive as earlier. This is a new computer, less tha
    Open the touchpad software, ASUS Smart Gesture, adjust sensitivity. Asua support : http://support.asus.com/Troubleshooting/detail.aspx?SLanguage=en&m=Q500A&p=3&s=450&os=&hashedid=n/a&no=1018
    Jan 10, 2013 | Computers & Internet
    Mouse won't left click
    mouse is most likely dead. you can switch the mouse properties so that the right key acts like the left key which requires uses of the window key on the keys board to access menu then use tab keys and then arrows keys to move to control panal the tab and use arrow keys to goto mouse and select switch primary and secondary button...but if your not into that just buy another mouse they re rather cheap
    Dec 07, 2012 | ASUS Computers & Internet
    Asus a8n-e m/b gets power, will not post
    Hello from here you can download a manual and drivers:
    http://www.asus.com/Motherboards/AMD_Socket_939/A8NE/#download
    My guees is that the windows disk is damaged or burned to fast.
    Since you not get any picture on screen now the graphic card. maybe malfunctioning try to change that and see what happens.
    A ps2 keyboard and mouse must be used.
    Because the usb function will not work until the system is fully installed.
    A restore disk does not contains a full windows its only for repair
    purpose.
    Good luck
    Nov 02, 2012 | ASUS A8N-E Motherboard
    RAT3 Button wont click
    i have the same problem now. It started with side forward button first, than my scroll button died and now LEFT is kinda halfway stuck :(
    Aug 02, 2012 | Saitek pc cyborg.rat3 mous
    ASUS 1000 left mouse button not working
    Yes! get a can of compressed air and attach supplied straw, now with your fingernail lift up the left mouse button and give a few good blasts in the crevice, this will clear out any buildup of dirt and grime that has collected, repeat as required. If this fails it will involve laptop service.
    Jul 04, 2012 | ASUS Eee PC 1000 Notebook
    Gaming mouse cannot detect
    try to plug into every usb slot... see if your mouse can still work or not... but i recommend you to bring that mouse and claim for it warranty....
    ps; if you plug your mouse into the PS/2 port, u need to restart your pc. i hope this will help you.
    Jun 13, 2012 | Computers & Internet
    I got my wife a mouse and key board a little wile ago' and she just now tryed to use it. the key board works but the mouse dase'nt how do i get it to work
    If its a wire less type check if there are batteries inserted and if the red LED lights up. If they do just click the left button to make it active. Even if you do not use it for more than 5 minutes the mouse goes into power saving mode, just left click to wake it up.
    Aug 16, 2011 | Computers & Internet
    My dell inspiron laptop's left click button isn't working as well as it use to, i think it maybe worn down, is there anyway i could get it replaced, and if so, where?
    Simple solution with less cost is please use the external USB mouse.(Small size also avaible in market.) You are not mentioned the location where you are, Please locate the nearest Laptop service center for repair/replacement.
    Try once with installing the Touch pad drivers.. .
    Jun 28, 2011 | Dell Inspiron 1750 Laptop
    Mouse will randomly double click or have to click several times to work
    Please check whether there are any buttons on the side of the mouse you may be clicking these at the same time as you are single clicking.
    You could also try going into Control Panel --> Mouse
    Try Slowing down the double click speed
    If that doesn't work try speeding it up
    Another problem with a laser mouse is it jumps around the screen randomly if there is a pattern on your mouse mat or desk, or if either are too shiny or even glass as the laser reflects incorrectly on these type of surfaces.
    Oct 18, 2008 | Logitech Cordless Mouse
    Computers & Internet Logo
    42 people viewed this question
    David Payne
    David Payne
