Question about Canon PIXMA IP3500 Photo Inkjet Printer
Print heads pixma ip3500
How do i install the print head and ink...i didnt get a set up sheet in the box.
  • Anonymous Mar 25, 2014
    canon pixma ip3500 wont print
  • 3 Answers
The user manual for your Canon Pixma IP3500 is here:
Scroll down from the top of the page to where you see 'product support information'. There is a set-up guide as well as the user manual. The information you need should be there. Good luck!
Posted on Jan 12, 2009
Why is Alarm code 5 flashes not going away?
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head.
Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.'
From Canon error page for 'Orange light blinking 5 times':
Description: The print head is not installed or has not been properly installed.
Description: A print head temperature sensor error has occurred.
Description: Faulty data of the print head.
Aug 26, 2014 | Canon PIXMA iP3500 Printer
Orange light flashing five times
With the printer on...
Open the lid
Remove the ink cartridges
Lift the print head lock lever on the left
Remove the print head
Gently clean out any ink
Gently clean the copper contacts on the back
Gently clean the print head nozzle(s) on the bottom
Make sure it's dry
Re-install the print head
Put the lock lever back in the down position
Reinstall your ink
Close the lid
Try printing again
The printer may detect that you removed/inserted ink so it may go through a print head cleaning of it's own that you need to wait to finish
If needed, power cycle the printer and then try printing again
You may need to replace the print head
Nov 11, 2017 | Canon PIXMA iP3500 Printer
My cannon ip3500 will not print in color ink tanks are full
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
Thank you for using Fixya
Aug 11, 2011 | Canon PIXMA iP3500 Printer
Canon ip3500 series the ink absorber is full contact the service center
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 07, 2011 | Canon PIXMA iP3500 Printer
Only prints other colors except black. Have change the toner but problem still exist.
Hi if you have put a new black ink in your machine and it still will not print black you will need to do a print head clean. you will find this on you pc in printer properties.
The problem is the ink can dry up and set in the print head so no new ink can get passed.
in the cleaning fails then you will need a new print head this is a part that you can if and if you go to Amazon and look for PIXMA iP3500 print head you will find it at about £45 ish
Yours Ian
Mar 17, 2011 | Canon PIXMA iP3500 Printer
I have the canon pixma ip3500. This is my second canon printer and I have the same problem I had with the first. The heads become blocked and no end of cleaning makes it work. Unfortunately I bought...
You can buy a replacement print head for your printer.
These are not cheap, they cost nearly the price of a new printer.
I suggest you Google search for replacement printer head for your model printer.
Oct 26, 2010 | Canon PIXMA iP3500 Printer
Canon ip3500 does not print black but colour ok ... whats up ... how to fix
1. this could be a clogged print head at the black cartridge. the head needs cleaning or the jets have clogged ports and cannot pass ink due to hardened ink.
This may require a print head replacement.
2.If you have recently place a new cartridge in the print slot check to see if you didn't leave the protective tape on the cartridge.
Apr 20, 2010 | Canon PIXMA iP3500 Printer
Printer won't respond to scan command (pixma mp450) and keeps telling me the cover is open when it is clearly not!
Press the OK button to
exit the error, and do
the print head
alignment again (from
printing of the print
head alignment sheet),
while confirming the
- Set A4 or LTR size
plain paper.
- Confirm that the print
is printed properly
(no smear or nonejection
of ink).
- Fill in all the
applicable boxes in
the printed sheet.
- Place the sheet on the
platen glass in the
correct position and
Oct 08, 2009 | Canon Office Equipment & Supplies
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Feb 26, 2009 | Canon PIXMA iP3500 Printer
Canon PIXMA IP3500 Photo Inkjet Printer Logo
722 people viewed this question
old marine
old marine
