Model BFW36B/Xac
SOURCE: Samsung washer parts
Try these sites: they should also have toll free numbers.
espares.co.uk
RepairClinic.com
AppliancePartsPros.com
SOURCE: not spinning or draining Samsung front load
Won't spin if it hasn't drained. Most probably a blocked/jammed pump impellor. Manually drain it from the lower drain pump (by side tube if that model has one, or slowly into a shallow pan. Remove cap completely & check for things jamming pump.
SOURCE: Kenmore 90 washer won't drain
How do I operate it? which program should i use for regular laundry?
SOURCE: samsung washer model wf203ans/xac
Hello
& Welcome to FixYa SE
or 5E is a drain error and is displayed due to a blocked drain filter pump assembly
that is located inside the front bottom panel of the unit. You have to clean it
and also clean the drain hose completely. Please get back to me if you have any
other questions. Kevin
