Question about Rival Stand Mixer 12 Speed Model Fprvsm0001
I need a replacement bowl - Rival Stand Mixer 12 Speed Model Fprvsm0001
    New Friend:
Too bad, website http://www.dealtime.com/rival-mixer-replacement-parts/products does not carry Rival replacement mixing bowls. I just checked.
Posted on Oct 17, 2016
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 55 Answers
Goto http://www.dealtime.com/rival-mixer-replacement-parts/products
Posted on Dec 07, 2012
KitchenAid ACCOLADE 400 Mixer.When mixing dough the bowl jumps out of the the bowl lock. How can this problem be resolved?
I know this sounds a bit simple but the bowl cup can sometimes actually wear out and a very fast (# screws) and a new one and the problem is solved. If however there is a problem on the head hold down set screw (under the mixer in the cavity ) it can come loose then the mixer head can bounce all over the place causung the bowl to get loose in the holding cup at the base of the mixer., I hope this helps, let us know if you need more, we can FixYa
Feb 22, 2015 | KitchenAid Food Mixers
I need a replacement bowl. LOVE the mixer!
Contact the manufacturer and tell them what you need. Normally the will send a complete unit instead of just the bowl because they can afford it anyway rather than split up a unit. This has always been the case for myself when needing a replacement part of that size.
Nov 15, 2014 | Rival Stand Mixer 12 Speed Model...
My bowl lift lever on the hobart (bought off ebay) K5ss doesnt lock the bowl into place. What do I need to do to fix it, or at least figure out whats wrong if something needs to be replaced.
On a bowl lift mixer there is a small metal clip on the back of the bowl support arm, it works in conjunction with a small "NIB" on the back of the bowl, when you put the bowl on the support arm there are two pins that the bowl rests on, on each side of the support arm, you place the bowl on the pins then press down the rear of the bowl untill the nib locks into the clip, if the bowl is not locking in place then one of four things are wrong, one of the pins are not on the support arm, the NIB on the back of the bowl has come off (it is spot welded on) or the clip at the yolk of the support arm has worn down or broke in half and there would be no locking action without it. The pins or the clip are inexpensive if it is the Nib on the back of the bowl you will need a new bowl. Hope that helps if not pleases get back with us so we can FiXya.
Oct 14, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer glass bowl broke. I need a replacement. I have a 4c mixer. Do you know where I can find one?
The glass bowl for the 4c mixer is much different than the bowls that are currently available. Your best option is going to be to find a used bowl off of eBay.
Your other option would be to replace the bowl lock plate and buy a new bowl for the mixer. I have had a few customers say this works, and I have had a couple say that replacing the bowl lock plate and bowl did not work. So you can give this a try as well.
Mar 28, 2013 | KitchenAid Food Mixers
My kitchen aid mixer bowl falls out when I'm mixing
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending Shed.com
Aug 12, 2012 | KitchenAid K45SS Classic Stand Mixer
My KitchenAid bowl keeps coming loose when kneading dough. Any solutions?
Hello Heather,
Apr 16, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
I need a replacement bowl for the braun km32 mixer
I have an extra bowl, but am in need of a regular whisk...any chance you have an extra and we can trade?
Jun 21, 2010 | Braun Food Mixers
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
Need replacement bowl for KitchenAid 3-C
put a watch on Ebay for the bowl they come on there once in a while
Jan 01, 2009 | Food Mixers
Rival Stand Mixer 12 Speed Model Fprvsm0001 Logo
316 people viewed this question
Top Rival Food Mixers Experts
Danny Kuhlmann
Tom Chichester
Are you a Rival Food Mixer Expert? Answer questions, earn points and help others
