Question about Cell Phones
Drop in water didn't turn on
  • Cell Phones Master
  • 14,641 Answers
Dear Brother:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Dec 07, 2012
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Hello, I have a problem!!! I have a 91 caprice classic with a 305 5.0L sbc. I bought another 305 5.0L sbc it's just from 1984 & had been rebuilt by a professional shop. It's board at 35 over. I...
This is a bit pf a custom car type lash up and untill you can get some local advice here dont use the car as the excess fuel will wash oil from the cylinder walls causing piston /and ring damage ,You need someone local who can sort out and re-map the fuel injection system for you just for starters,Nice try and do admire greatly your determination in making something work but as iam in spain iam not a lot of help on this matter also owing to europeon vehicle law i wouldnt be allowed to do this for a rad vehicle as it detract from the certificate of homoglonation so a non standard vehicle just isnt allowed ,cannot even change the back lights for a fancy one let alone a engine
Feb 24, 2013 | Cars & Trucks
Turned camera on gives error message to turn off and back on again . No matter how many times we turn off and on it won't clear the message. Took battery out.put back in. Message still there. Also len
Camera was probably dropped. Motorized autofocus lens was probably damaged when dropped. It doesn't get more of a big deal than this. Depending on age of camera, it may be a ''wipe-out.''
Ps... I'm saying ''probably'' dropped because I didn't see it happen, but this is precisely what happens when they are dropped. It doesn't take much of a ''jolt'' to do the damage, and there is usually never any external damage.
Oct 09, 2012 | Cameras
Alicia perle H20
H2O is the chemical formula for water - maybe it needs filling with water ?
Sep 22, 2017 | Cameras
2000 FRONTIER DIES WHILE DRIVING IT WILL RUN WITH ON LIGHTS BUT IF TURN ON ANYTHING ELSE IT DIES
you may not believe me when i say this but your not pulling enough amps from your alternator mine did the same thing its in your belt sytem usually caused by a water pump being out of balance replaced my water pump and runs great! hope this helps P.S. my pump didn't seem to be bad it felt free and didn't feel like it had any wobble but apparently it did
Nov 03, 2011 | 2000 Nissan Frontier
Handle came off in shower. Put back on & can't turn water on...
On some faucets there is a set screw at the base of the lever and others have a set screw under the top cover. It sounds like your handle worked itself out and when you put it back on you didn't tighten the set screw. So the lever is turning but not engaging the valve stem.
Sep 18, 2011 | Home
2003 NSR125 lights all went out on the way to work this morning & Rev counter dropped to zero and didn't move although the bike didn't shut off as soon as i turned the engine off no electrics...
you will need to find out if the battery is being charged when the motor is running.if it isnt you will have to check wiring from the charging system.There could be a problem with the regulator/rectifier unit.
Jun 17, 2011 | Honda NSR 125 R Motorcycles
Running hot after 12 minutes of operation, supposed to have been replaced (water pump, thermostat, and timimng belt, pulled radiator today, it flows but to what extent ??? I recently had the water pump...
With the engine cool, maybe in the morning. If you have some jugs to put water in fill them up, and put them someplace warm if possible, or just use hot water when your ready to work on it. Take the radiator cap off start the car let it run. (we know it gets hot in 12 mins) You should be able to see the fluid in the radiator move quite a bit after it's warm. If what I'm hoping is the problem, the radiator fluid level will drop a lot maybe as much as a third. If this happens add that warm or hot water to the radiator until almost full. It is bound to hick up a time or to so be careful as you said the temp gauge was at 220 degrees. (hot enough to melt your skin off) Give it a few more minutes as thermostat hopefully is opening and closing. After the fluid level in the radiator stays consistent, place cap on radiator. Let it cool off, how ever long it takes would be best if could wait till temp gauge is close to cold start position. Start it up and see if this helps, if they did indeed replace things, which don't always leave a lot of tool marks. Then maybe they just didn't burp/bleed the cooling system of air. So your cooling system will not work as there is no water in the block only in the radiator. This is a long shot, but only take 30 minutes, at most and a little bit of water. Hope this helps, let me know if it does.
Jun 12, 2011 | 1999 Chrysler LHS
Didn't LG produce some bad Humidifiers several years ago and have a recall on not working units? I recall reading this in Consumers Reports. I bought one back then and it has not produced a drop of...
If has not produced a drop of water for several years, then it's not working properly. But, this may be a case of setting the humidity level to high. In other words, if you set it at 70% or Maximum, that's the humidity level that it will maintain, not remove. To remove humidity, the level must be set low (35% or Minimum).
To test the unit, based on what I just said, place it in the bathroom, set the level as low as possible and turn the shower on medium hot. Do Not turn the bathroom exhaust fan ON. As you leave, close the bathroom door. Return in 15 minutes, turn the shower OFF and check the bucket water collected. If there's any water in it, it's working fine. It was probably a case of the humidity level being set to high.
Hope this helped you. Please let me know. Thanks.
May 16, 2011 | LG DH305 Dehumidifier
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
