Question about Samsung Soc-a101 Hi-res Outdoor Bullet Camera, Sme-2220
Where would I find the wiring diagram for a Samsung Security Camera SOC-a101? It is a 6 prong plug and I need to connect a PS2 connector to it.
Need wiring diagram for Samsung a101
Posted on Dec 08, 2016
I have a Samsung soc-a101 digital color security camera, wires corroded off male plug to camera what is the wiring sequence to the plug? wires are: red 12 volt looking at pin's front side not back of plug, from plastic tab pointed up red is on right top terminal, audio is top left terminal which I assume is white wire, then I have a clear plastic covered wire and the bare stranded wire. what terminals go to these wires I assume the bare wire goes to the metal ring of the plug as it had a wire soldered to it just don't know which! this leaves the bottom pins on the left and right set of two and the two bottom pins! Can you help? remember I am looking at the front not back where the wires are soldered. Thanks.
Posted on Jul 03, 2013
2 Suggested Answers
SOURCE: I need a wiring diagram for soc-n120 camera
1 2 3 4 5 6 Green Red Yellow Bare Gorund Clear
Cover
Black RJ11e color & slot. Orientation Lock Pin Down. Wire at bottom
Posted on Dec 04, 2012
How do I connect the sound in my camera
Use the sound wire that came with camera one has one male pin and the other end has two colors pins one red and white.
Aug 13, 2014 | Samsung Security Camera Soc-c120 Color...
How is the sound connected in the samsung soc-c120
If it has audio capabilities it will have an internal pickup for the internal microphone, make sure the input is not covered or being shielded to the point it cannot clearly pickup any sound.
Aug 13, 2014 | Samsung Security Soc-n120 Color Camera...
My 3g isnt working how can i fix it
Check your sim card. If the connectors or only one connector is dirty or oxidised it could cause the trouble. You also could walk in a stroe from your providor and ask if they can help. They have spare sims to test if it is the sim or the phone.
Jul 05, 2014 | Samsung Security Cctv Sod-14c Soc-120...
I need to conenct yamaha rx v420 to Samsung tv
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V420.pdf
Mar 31, 2014 | Samsung Security Cctv Sod-14c Soc-120...
Cover
May 10, 2012 | Samsung Security Color Camera Soc-n120 +...
We purchased a home with 4 samsung cameras in various places around the exterior. They are all wired back to the master bedroom with what looks to be CAt-5 cable. What do I need to make this system work??...
Hi there, depend on the model of your cameras, normally if there are samsung it should say the model # ( ssc-12c,soc-c120 and so on) What look like CAT-5 are normally RJ-11 very similar to a phone connector. If your cameras are one those mentioned above you will need a monitor that support that type of connection like the ssc12m or ssc-17webm if there are black and white or the SMT-190M if there are color cameras. or a DVR with similar connection type like the SHR-1041.
Thank You,
nationalprosecurity.com
Oct 17, 2010 | Samsung Weather Resistant Security Camera...
Samsung survalance cam sod12c
check on the electronic board inside the camera, you will probably see a few condensator with a "-" on it, just follow the connection and your negatif wire will be connected to it...
cheers
Dec 20, 2008 | Samsung Color Fixed Security Camera...
PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Dec 09, 2007 | Sony PS2 Dual Shock 2 Controller...
Samsung Soc-a101 Hi-res Outdoor Bullet Camera, Sme-2220 Logo
986 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
bobby little
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
