Question about Canon PIXMA MP780 All-In-One InkJet Printer
My canon pixma mp 450 start pass a page and then it say error number 5100
  • Anonymous Feb 04, 2009
    idem
  • 412 Answers
Follow these inst....
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
Error 5100 for canon mp 287
Error 5100 for canon mp 287 - Canon PIXMA
Dec 22, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
ERROR 5100 CANON PIXMA MP 450 It does not work when off from KOPJUTER
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 17, 2010 | Canon Pixma MP450 All-In-One InkJet...
My Canon pixma Mp 450 printer is showing error code 5100 what is wrong with it?
it is service error you can fix this by doing this steps
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 19, 2010 | Canon Pixma iP4500 InkJet Printer
Error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
Sep 13, 2009 | Canon PIXMA MP470 All-in-One Printer
Error 5100
error 5100 in all Canon printers is almost always something simply blocking the carriage.
Jul 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Service error in canon pixma ip 1200??
Hello,My problem its Pixma IP 1200 for Windows Vista PLZ Help!!!
Jun 16, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon MP 160
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-2
Feb 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
