Question about ViewSonic Va2431wm LCD Monitor
The screen occasionally darkens significantly,
From time to time the screen will darken and the brightness will not be restored for a variable period of time. When I turn the monitor on (or bring it out of what I presume is standby mode), it first shows a dark version of whatever should be on the screen, then goes almost black. I am almost positive this has nothing to do with the settings. Sometimes I can fix the problem by unplugging the vga cable, while other times I just have to wait it out.
  • tdizzogger7
    tdizzogger7 Jan 28, 2013
    I recant, wiggling the cord around in the socket seems to do the trick, so I guess I'll grab a new one! Thanks!
    Guru:
  • 571 Answers
Have you tried using a different VGA cable? Or replacing the cable with a new one?
Posted on Dec 07, 2012
  • tdizzogger7
    tdizzogger7 Dec 15, 2012
    the problem persists when the cable is unplugged, so that shouldn't be the problem...if only :(
3 Suggested Answers
SOURCE: The screen is to bright and wont darken enough
It is likely the video card on the actual unit. If it is under warranty they will likely have you ship it back to them for either 1) repair or 2)replacement
Edwards-Walnut
381 Brea Canyon Road
Walnut, CA 91789
Posted on Jul 07, 2009
budmrtn
  • 11361 Answers
SOURCE: monitor takes a long time to
Look for bad caps (leaking/bulging) as shown in my pictures:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 07, 2010
Screen stays black, you can still hear it snapping pics
Manaual says:
Standby mode for saving power: press the shutter-release button halfway.
Camera and computer are connected via the USB cable.
Camera and TV are connected via audio/video cable or HDMI cable.
Adjust monitor brightness.
When the internal temperature of the camera is high, the monitor darkens to reduce heat generation. When internal temperature cools, the monitor brightens again.
When the power-on lamp is covered after the camera has automatically increased monitor brightness, the monitor may darken.
If you did not drop teh camera, or cracked it in your backpocket, perhaps you also chould check the battery. If it is charged, and still has enough capacity.
Nov 05, 2013 | Nikon Coolpix S100 16.0 Megapixel, 5x...
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Edwards-Walnut
Walnut, CA 91789
Apr 05, 2009 | ViewSonic VA903B Monitor
Pelco monitor display is darkening
There is another brightness adjust on the back of the monitor.
Feb 19, 2009 | Pelco Pel Monitor 12" B/W
Monitor is too bright
Lcd monitors do not go overbright due to aging,they may go dim due to backlight aging.Do front panel controls work and if so what happens when you try to bring down brightness?
Some monitors have a "Recall" function which is a factory restore bringing all setting to factory value.
Try this if available.
Samir
Mar 07, 2008 | Gateway FPD1760 17" LCD Monitor
Acer AL1715 - insufficient brightness
No there isn't any. there is probably a part that is damaged due to the surge u should get a new one or send it back to the company
Feb 02, 2008 | Acer AL1715 17" LCD Monitor
ViewSonic Va2431wm LCD Monitor Logo
79 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
