Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Pinkish Color on Monitor
I have a Samsung LCD monitor and today I jiggled some wires attached to my computer and then screen on the monitor now has a pink color to it. I tried to reset it but it didn't work. Does anyone know what could be wrong?
  • Nancy Walker Jun 10, 2007
    Thank you so much. I wiggled the cord and the pink disappeared. I will get a new cable.
If this type of problem seems to be in moniter then at first check it.
1.check the VGA cable is it attach properly, also check it's pins because might be any pin could be bent.
2.check the moniter colour setting and reset it.
3. otherwize second thing is restart the system and go on BIOS utility here check that the issue is same or not, if the patches are still showing that means the problem is with the O'S
and if it's not being in BIOS that means the problem is with moniter, then check the graphic card driver on device manager, is it intalled properly or not if not then uninstall the driver and istall it again,after that if problem will insist then the problem is with moniter may be that colour has been disturb through magnetic effect.now it will'b repair
Posted on Mar 18, 2008
    President:
  • Samsung Master
  • 1,314 Answers
Most likely it is your VGA cable gone bad. I remember doing a warranty call for HP once, I was the third tech to go out and replace a motherboard. When I got there, I found out that the cable was bad and it was giving everything a blue tint. I would certainly recommend replacing the VGA cable. I bet if you wiggled the VGA (monitor) cable on the back of your computer, it will come and go.
Posted on Jun 10, 2007
Hi, My monitor will once in awhile go from the warm white color to a slightly red or pinkish color. The monitor is about 5 years old and the model # is AL1913. Any thoughts? Thanks. Don
Red or pinkish cast on the whole screen? You may want to check the VGA connectors and pins at both ends. Also try it with anothe PC to make sure it is not video problem in the PC.
Basic LCD monitor and LCD TV troubleshooting guides:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
Dec 15, 2010 | Acer AL1913 19" LCD Monitor
Monitor color is pink at switch on. 5-10 minutes after normal
There are many things that could be causing that, but to fix it would take some electronic equipment, schematic, and know-how. It could be as simple as a faulty potentiomet, but a shop would charge you more than it's worth to fix it. My advice is to live with it until it gets too bad, and invest in a new one If you're not ready to advance to the LCD monitors yet, check with a Used Computer Store- they usually have CRT monitors at a reasonable price. Hope this helps.
Mar 25, 2010 | SAMTRON 55V 15" CRT Monitor
After display goes black monitor green power light remains ON. Power can be turned of and the display again stays on approximately 5 seconds. Replacing capacitors in power supply did not correct the...
The problem can be the lamps are bad, the only way to tell is to remove the lamps, look for poor soldering works where the wires are attached to the lamps, bad lamps will have very dark color at the end of the lamps, just like bad fluorescent lamp you see when it is worn out, anoher sign of bad lamp is pinkish glow when lamp si first turn on. The transistors and caps are good in the inverter section?
Jan 02, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor led is green when vga cable cunect but on diesplay on monitor?
if the screen is only green then unplug and replug the cable but this time hold it on to the connection and jiggle it until you see the screen's color back to normal, if not then there might be a problem with the monitor's congifuration on the lcd screen or even in the system under the drivers or the wire is busted
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
Aug 10, 2009 | Computers & Internet
Pink Monitor
Are the monitor and computer both new or are they used? If the monitor is used then I would bet the problem is the backlight tubes. The backlights in LCD monitors are fluorescent lamps just like in your house or office. When the bulbs get old and about to burn out the output light changes from white to a pinkish color. At this point if your monitor is several years old and you have a pinkish display you need to start looking for a deal on a new unit. It is possible to replace the tubes but it is very hard to do because they are so small and fragile.
I hope this helps.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jul 10, 2009 | HP Computers & Internet
After replugging lcd monitor and starting comp it was pink
Try disconnecting the VGA cable from the computer and checking that the pins in the connector are all straight
Mar 22, 2009 | Gateway 19" Flat Panel LCD Monitor
N0 or Very little backlight on Samsung SyncMaster740 17" Monitor
back light is going bad. if you see a pinkish hue on the" checking signal" box on screen when it comes on. Should be white.
Feb 22, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
My samsung monitor was working just fine yesterday but today the screen is black and the green light is flashing....I have made sure that all the cables are properly attached...
Step one is to try hooking up your monitor to a different computer. If that does not yield a different result then it is likely going to be a problem with the power circuit in the monitor.
If your monitor is still under warranty then you should be ok, if not then you can contact Samsung for help by using THIS webform.
You may also be able to get this fixed at a local TV repair shop, but you best answer, considering the smallish size of that monitor would be to go buy a new one. Many decent LCD monitors can be had for about $100.
http://ars.samsung.com/customer/form/formmail/usa/input_SEA.jsp?SITE_ID=1&PROD_ID=28
Jan 02, 2009 | Samsung 15.3" LCD Monitor
LG lcd computer monitor
try to connect your old monitor and adjust your screen properties down to 800x600 with medium color setting..or go to xp safe mode, adjust screen properties to the lowest setting, xp has not yet installed the monitor driver of your lg lcd monitor.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Pinkish monitor
the monitor is on its way out ,
time for a new one
Terry
Mar 29, 2008 | Computers & Internet
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
193 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
