Question about Polk Audio POLK PA1200.1 1200 watt monoblock amplifier
Need circuit diagram for a PA1200.1 class D monoblock car audio amp
Amp is getting power from battery and blue accent lights turn on, but no power to the subs. Tried direct connecting an mp3 player to amp to eliminate RCA cables and still no sound. Amp was wired at 1ohm for 3 months and working ok. Got warm one evening and went into protection mode and hasnt worked since. Amp only got pushed hard for ten to fifteen minutes at a time, but only about once a week for those few months.
shaggyrat
  • 1224 Answers
SOURCE: SUBS
the bigger the wire the better the resistance but even a wire wont do much
the only thick i have on my sterio is the battery wire the rest is cut old extension cord wires and mine sound fine never cut out on me and i have 1600 watts going threw amp
more power putting threw the hotter the amp hotter the amp more the cut off amp
quite possible you have too much power going to speakers if your bridged it will blow out amp found that out from bridgeing but thank god i had it fused
turn down your gain and bass boost and work up to good sound say your sterio is 1-60 volume your should hit right around 30 volume by turning gain and boost untill quality sound this is your safe zone gain should be set 1/2 volume of sterio to 3/4 pushing it nothing more or total melt down
Posted on May 07, 2008
rteemon
  • 578 Answers
SOURCE: red protection light is on constantly. the light won't turn green
is the remote source have enough amp to triger amp seem like that is you prob and chk you spk wire and rca too-
Posted on Jun 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: Polk Audio DSW Pro 500
Is this NEW? Or did it just fail spontaneously after working for awhile?
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Posted on Mar 06, 2011
SOURCE: 5channel amp 6 speakers how
if it is a 5.1 channel amp wire the center speakers together into the same port. wire the two front speakers in the or der that they would appear on the amp (such as left front speaker to the left front speaker terminal on the amp etc.) and do the same for the rear speakers. and all you should have left is the sub-woofer channel in which you do not have to worry about.
Posted on Jun 04, 2011
  • 11800 Answers
SOURCE: I have a Polk Audio
The protect light appears when one of the outputs on the Polk is shorted - the cause of this can be internal or external.
To find out which just disconnect all the speakers from the Polk and start it - if the warning is gone then it's external, one of the speakers (or its wires) is shorted, connect them one at a time until the warning returns and you will know which one. If the warning is still there then it's internal, one of the amplifiers inside the Polk has failed and it will have to be taken out of the car, dismantled and tested by a pro to find out what happened .
Posted on Jun 06, 2011
My planet audio px4000d amp powers on but green or red light dont come on
disassemble check internal fuse or for burned track also recheck the antenna connection -the thing that powers the amp on.Use a multimeter to test different points to ground potential. the one that doesnt have it has the problem.
Jun 22, 2014 | Planet Audio PX4000D Class D Monoblock...
Got a service manual / circuit diagram for an OV2-800? I have one keeps blowing input fuse when remote wire is energized.
Hi, are you using the blue wire from the head unit to turn on the amp? The turn on voltage is more like 5 volts--not battery voltage, so you have to use the blue wire to turn on many amps.
Feb 09, 2011 | Power Acoustik GOTHIC OV2-800 Car Audio...
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
I HAVE A JL AUDIO MONOBLOCK AMP 250
It indicating that the power output is too loud and possibility of speakers may get damaged if played at this volume for long periods. When the loudest sound is played the led light mightshow its loosing its brightness and dims in time with the sound level.......................sodeep
Jan 17, 2009 | Jl Audio 500/1 Car Audio Amplifier
Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Jan 08, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
My 7801 doesnt turn on
check pwm circuit amps turn on with 3-4 volts on mosfet gates ic 494, 5252or 555 controll these.hit me up for more
Apr 03, 2007 | MTX THUNDER7801 SUPER AMPLIFIER CLASS D...
Polk Audio POLK PA1200.1 1200 watt monoblock amplifier Logo
50 people viewed this question
Top Polk Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Polk Audio Car Audio and Video Expert? Answer questions, earn points and help others
