Question about RCA TruFlat 27F520T 27" TV
RCA model#32V420T Will not turn on with remote or manually how can we fix it?
Turned iy off with the remote and it will not come back on changed batteries in remote still not working tried power button on front of the TV and it will not come on
  • GHsZaIl Dec 07, 2012
    my best friend's step-mother makes $87/hr on the laptop. She has been fired for six months but last month her payment was $14952 just working on the laptop for a few hours. Read more on this site http://Fab77.com
    Top Expert:
  • RCA Master
  • 14,553 Answers
This set is part of a group of RCA sets made a few years ago that all have something in common.
We see them come to our shop: will not turn on with or without a high pitched whine before they are turned on
Understand I have seen and repaired about 40 of them---In all cases the High voltage transformer is bad and most of them also the horizontal output transistor (that part is connected directly to the transformer.
I am familiar with this kind of issue and what I first noticed was the transformer was a bit small in size for the job it does.
Regardless, the parts needed are no longer available from RCA but both parts the set will need are available in a Generic way---Total parts cost is under 35 dollars for both (they are soldered into the main board) and I or any good tech can replace both and have the set working in less than a hour---I average about 30 minutes total time.
Here attached is a photo of the transformer and the transistor is easy to find.
RCA model#32V420T Will not turn on with remote or  - 12_7_2012_1_45_20_am.jpgsimilar to this in looks.
based on my experience both parts will have to be replaced to get the set up and running again, not just one or two of the sets had this, there are about a dozen models from 27 to 36 inch screens with this.
Posted on Dec 07, 2012
TVtechmaniac
  • 140 Answers
SOURCE: FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Posted on Sep 13, 2007
  • 3 Answers
SOURCE: RCA 32" 32V420T
YOU AVE TO CHANGE PROSESSOR IC I THING THE PARTS NO. IS TLC-A27VO2-TO, AND ADJ. YOUR SET WHIT SERVICE MENU.
Posted on Jul 24, 2008
elx2k7
  • 3 Answers
SOURCE: RCA 32V420T Quit
replace eeprom
Posted on Oct 28, 2008
jingjao
  • 252 Answers
SOURCE: RCA Guideplus Gemstar TV
one of the button switch is still working or stock up, you need to replace all the switch to besure.
Posted on Oct 31, 2008
  • 4 Answers
SOURCE: I manually turned on the FPA button in error on my
Probably the front panel board. Heard many that have problems turning on and off.
Posted on Feb 17, 2011
I have a RCA model number 32V420T & I accidentally turned on the FPA, turned off the tv & now the tv won't turn back on. It doesn't have the original remote to it & can't turn the tv back on.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Nov 04, 2016 | RCA 32V420T 32" TV
I attempted to see if I could get the menu to adjust the screen because the bottom of picture was not showing on screen and somehow turned the FPA ON...by mistake Now tv won't turn back on and I don't have...
is there a menu on front of tv if so push it then use the chan up/down and vol up/down to select what you want. Now if there is not a menu on the set then push the chan up and down at the same time on some sets this will let you into the menu give it a try good luck.
Jan 02, 2010 | RCA 32V420T 32" TV
Scott TV remote not working
yes the sensors on all sets go bad and the remote signals will never get to the eprom chip that takes the signals and processes them
Dec 29, 2008 | RCA 32V420T 32" TV
Rca 32 inch tv
Its proberally the main controll ic, or the remote sensor is malfunctioning. you will need to check the remote sensor by disconnecting it,, and if you still have the problem then you will have to change the main board.
Jul 22, 2008 | RCA 32V420T 32" TV
RCA 32" 32V420T
Jul 02, 2008 | RCA 32V420T 32" TV
Rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
Dec 23, 2007 | RCA 32V420T 32" TV
No picture or anything
If your model # is 32V420T, your TV probably has a bad
transformer = part # 271996............if not,please provide......T.
Nov 05, 2007 | RCA 32V420T 32" TV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
RCA TruFlat  27F520T 27" TV Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
