Question about Proview PL926WBi 19" LCD Monitor
19inc moniter power on then goes off within 1 sec
  • 6 more comments
  • Anonymous Feb 04, 2009
    I have the same problem but my Windows start up screen appears first.
  • belgies Feb 12, 2009
    Same with mine comes on for a second then black screen can it be fixed?
  • Anonymous Feb 24, 2009
    Same problem here. statrs up then quits after a second or so. If I turn it off then on againit does the same thing
  • Anonymous Mar 10, 2009
    Turn monitor on, 2 or 3 seconds later, the monitor goes black.
    It will stay on for up to 20 seconds some times.
  • mark7671 May 15, 2009
    done caps still same put a volt metter on and opnly got 9volts runnin throw bored
  • Raynell Reynolds
    Raynell Reynolds Jul 08, 2009
    Had the same problem; sent it back to the manufacturer for repair. 6 months later (after the warranty was expired) it started to do the same thing. I don't recommend this product to anyone.
  • 558 Answers
Bad capacitors in the power circuit for the inverter power supply, replace these and everything should be alright it requires soldering skills or I can do it for a fee. It can also be transistors but much more likely it is capacitors.
Posted on Mar 21, 2009
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Tip
Error code CANON iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
on Dec 18, 2009 | Office Equipment & Supplies
Tip
Error Code iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
E001
0000
0001
0002
E002
0000
E003
0000
0001
E007
0000
E010
0000
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
E064
0000
The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
on Dec 08, 2009 | Office Equipment & Supplies
Moniter goes black 2 sec after i turn it on and when i turn off then back on it stays on for 2 sec then goes black again
Look for bad caps, shorted out transistors, cold solder joints. You will have to do in-depth troubleshooting and you need to narrow down the problem to find out if it is the lamp assemblies problem or the inverter/power supply problem.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 02, 2010 | Dell SE198WFP 19 inch LCD Monitor
Hi i have a 19inc tevion and the power pack has blone up and i dont no were toget 1 just wondering if u could tell me were to get 1
Well If your Lucky...Check On the Net ...Exemple Type.... Download (the brand and the model of the TV end Search on yellow page Any Business and check for Phone ..Web pages anything under TV Repair.. Check also on Radio Shack those type of Electronics Stores ...Good Luck.
Oct 06, 2010 | Televison & Video
Syncmaster 216 bw samsung goes black. when i push
your power supply needs to be repaired . you have bad capacitors. very comon problem
Dec 31, 2009 | Computers & Internet
HOW TO PROGRAM 2003 TOYOTA CAMRY FACTORY REMOTES
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
Sep 17, 2009 | 2003 Toyota Camry
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Gateway FPD1960 TFT works with laptop, not desktop
Elbtax,
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Mar 18, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
403 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
