Question about LG WM-2277HW Front Load Washer
I have LG wm-2277HW Front Load Washer, when I pour bleach into the bleach dispenser I see it disappearing as fast as I pour it in,and I see it coming out the front bottom the washer (the same side) where the bleach goes, what's wrong?
    Top Expert:
  • LG Master
  • 9,472 Answers
Remove the screws on the back of the top and lift the top off. Pour water into the bleach dispenser and watch to see where the leak is coming from. Post back your findings.
Posted on Dec 07, 2012
  • kevin wegrecki Dec 12, 2012
    Will be busy on it this weekend, I'll let you know whats up. Kevin
  • Richard Roth
    Richard Roth Dec 12, 2012
    Keep me posted.
  • 489 Answers
SOURCE: Problems with LG WM-2277HW Front Load Washer
It is a rare problem but I've seen it happen.  The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser.  The dispenser can be disassembled by unsnapping the top section where the hoses are connected.  Once the top section is lifted, you can safely pull the drawer out.  Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer.  Recommend replacing the dispenser to resolve this problem.
Posted on Jul 24, 2008
  • 210 Answers
SOURCE: LG Front-Load Washer WM2277HW ce sign
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Posted on Jun 08, 2008
  • 210 Answers
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
Sgt 48
Need the washer schem
Posted on Nov 26, 2008
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
Which side of the dispenser does the detergent go?
The detergent goes in the front left side,their is a blue cup their if using liquid,pour it into that cup,if using powder detergent remove that cup and the powder goes there. The Bleach would go behind the detergent& and softner would go in the right rear compartment
Gene
Aug 21, 2011 | LG WM-2277HW Front Load Washer
I accidently poured my fabric softener in my bleach dispenser!!. I'm not an idiot--I just took migraine med. & I guess my head was fuzzier than I thought!! What should I do?
Pull the dispenser drawer forward until it stops. Push the tab down at the back side of the drawer to allow you to remove the drawer the rest of the way out of the machine. Dump out the dispenser drawer, re-install dispenser drawer.
Sep 25, 2010 | LG WM-2277HW Front Load Washer
The frabric sofener and bleach will not empty in model lg wm-2277hw
This happened to mine about 2 years ago. I replaced the cold water valves/solenoids and this corrected my problem. The cold water inlet has 3 separate valves. One of the hoses that leads from it dispenses water into the softner and bleach sections "cups". I hope this helps, (I just got through replacing it "again" yesterday and one of the pumps that removes the dirty water out the drain)
Sep 06, 2010 | LG WM-2277HW Front Load Washer
No bleach dispenser
Bleach can be placed in your middle compartment, where you would normally pllace your fabric softener.
May 05, 2010 | LG WM-2277HW Front Load Washer
Water stays in softener and bleach dispenser after washing
water stays in the softener and bleach dispenser after washing and also the bleach is not dispensing
Apr 26, 2010 | LG WM-2277HW Front Load Washer
Can I use bleach with the laundry detergent for a load of whites?
Hi
Thanks for using FixYa. You need to preload all your detergents/liquids in a tray and let your washer do the work. No more “figuring out when to add softener, bleach or detergent”. The electronic controls on the LG WM-2277HW are clearly labeled and easy to use. This washing machine comes with standard dispensers for fabric softener and bleach and there is also a detergent dispenser.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | LG WM-2277HW Front Load Washer
Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Bleach spots with HE detergent
I have learned the hard way that after I wash a load with bleach, I have to remove the dispenser drawer and wash it out. The bleach in the compartment isn't always entirely used so when you wash another load, then it gets the remainder that wasn't flushed out.
Nov 10, 2008 | LG WM-2277HW Front Load Washer
Lg wm-2277 dispenser tray
Hiya Vanch... disconnect the electric.. remove the lid screws at the rear.. slide from the front to the back with lid.
Depress the tab at the top of the drawer "gently" whilst easing the drawer from the machine.
Refit lid.. connect up to electric.. Sorted!!
Regards Faggly
Mar 19, 2008 | LG WM-2277HW Front Load Washer
LG WM2233H Washer
Most likely the small electric motor that moves the water injection pipe on to the various outlet mainifolds has stripped its plastic gears, afraid the only solution is a new soap dispsener assembly
Oct 01, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
566 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
