Question about Kodak EasyShare Z760 Digital Camera
WHAT IS THE BEST MEMORY CARD FOR THE z760 CAMERA
  • charleneethr
    charleneethr Dec 11, 2012
    Yes thank you we had the wrong size memory card
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
The Z760 works with MMC and SD cards. MMC cards are all but extinct, and samples will likely cost more. MMC and SD cards max out at 2GB, so make sure you get one no larger than 2GB. SDHC cards start at 2GB but won't work in the Z760.
You can use any speed and brand of SD card, but personally I'd go with one of the major brands.
Posted on Dec 07, 2012
  • 4 Answers
You can use any brand SD but not more than 2GB capacity for more help visit www.kodak.com
Posted on Dec 08, 2012
3 Suggested Answers
  • 11967 Answers
SOURCE: sdhc memory card wont format on my z760 camera
Check your manual. Does your camera accept SDHC cards?
Posted on Aug 30, 2009
SOURCE: Sdhc memory card won't format on my Z760 camera
SDHC cards will not work with this model...sorry
Posted on Feb 28, 2010
I put a SDHC memory card in it and it said to format it.
The Z760 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Aug 28, 2011 | Kodak EasyShare Z760 Digital Camera
I have an EasyShare Z760 Digital Camera w/ the dock. My camera was working fine yesterday however I tried to transfer pictures today w/ no luck. I plug the dock into my computer (same computer I used...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jun 17, 2011 | Kodak EasyShare Z760 Digital Camera
I just put in a new SD card in Kodak Z760, but it needs to be formatted. How do you format the card?
There is a function to format memory cards somewhere in the camera's setup menus, but this might not be the problem. Most cards come pre-formatted. If this card is more than 1GB it will be SDHC instead of SD. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
There is no reason not to try formatting the card, but if it won't format or isn't usable after formatting, then it may be incompatible.
Nov 27, 2010 | Kodak EasyShare Z760 Digital Camera
Memory card will not format in Kodak Z760
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 22, 2010 | Kodak EasyShare Z760 Digital Camera
    Kodak z760 lcd screen will not work in the auto
    It could have something to do with the batteries/ battery compartment: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
    Jan 14, 2010 | Kodak EasyShare Z760 Digital Camera
    My Kodak Z760 Camera will not format your 4gb SDHC card. Kodak says the Z760 can use anSDHC card.
    Be shure that the tiny "Lock" switch on the side of the card is not in the locked position.
    I bought an SD card on sale to find that it was manufactured poorly and the lock switch would push into the locked position when I inserted it.
    Manufacturing defects are not uncommon.
    Also be shure you have sufficient battery power.
    That's all I know about that.
    Cheers,
    Richard.
    Dec 04, 2009 | PNY 4GB Secure Digital High Capacity...
    Sdhc memory card wont format on my z760 camera
    Aug 29, 2009 | Kodak EasyShare Z760 Digital Camera
    May 20, 2009 | Kodak EasyShare Z760 Digital Camera
    Kodak EasyShare Z760 Digital Camera Logo
    154 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
