I forgot my password for wireless so I reset me router and now I cannot figure out how to re connect. My pin is not working to get in. I am on the IP page I don't know what to so next
  • 7,627 Answers
If you reset your "pin"/security key, doesn't work anymore. Depending on the Make of the wireless device, you didn't mention, you use a default, say "admin", for instance, with no "pin"/security key.
Posted on Dec 07, 2012
roadhawk
  • 25 Answers
SOURCE: IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Posted on Nov 25, 2007
  • 556 Answers
SOURCE: router password
Before following this procedure beware that the reset function on the router will probably reset the entire configuration to the factory original. You will probably need to completely reconfigure your router after the reset including WAN side IP address or dynamic and possibly PPPoE userid and password if required by your ISP.
click on the following link
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1175238819816&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1981633391H10
select your region and country
Select Choose a Product
Enter your product or navigate to it.
Download your user guide.
It should have instructions for resetting the router as well as reconfiguring the router.
Posted on Dec 09, 2007
SOURCE: Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Posted on Nov 20, 2008
nyilasrobert
  • 627 Answers
SOURCE: how to reset Edimax BR-6204Wg router? default wireless password?
push reset button at least 10 seconds
Posted on Jul 10, 2009
  • 40 Answers
SOURCE: i forgot my admin password for Wirelles Router
if you havnt changed the password to the router then it should either be "PASSWORD" "ADMIN" "ADMINASTRATOR" in the worst case senreio you may have to reset the router.
Posted on Apr 20, 2010
I forgot my routers password, how can i get back the default settings
You can get factory defaults with RESET/WPS button it is i the back side of router press hold it for 10 second then all settings goes defaults. Then follow below to reconfigure it. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa
Sep 06, 2011 | Linksys WRT54G2 Wireless Router
Describe your 802.11g Wireless Router WBR-1310 (WBR1310) Problem I forgot/can't find the password to connect to my wireless device.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 24, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I forgot the security key
Jun 25, 2011 | Linksys WRT120N Router
I forgot my internet password. how do i get it?
What Password did you forget if you forgot your password for your ISP then you will need to call them if it for the access point then just reset it and you will have to set up the security again Reset button is usually located on back of router/access pointuse a toothpick or similar object to depress button for approximatly 10 seconds.
Good Luck!
Jun 10, 2011 | D-Link DIR-615 Wireless Router
I forgot my password and my username
You can reset the router by following below steps, this will automatically bring you to set password:
1. Find the reset hole which is placed in back of the router.
2. Place a pin or pen tip on the reset hole and press the pin (Must do this while the router is in ON state and as well is in OFF state)
3. Then connect your router through ethernet port to computer.
4. Configure new password to the router.
Most probably the router IP address is 192.168.1.1
Username: admin
password: password
Please try this steps and provide your valuable feedback.
Thanks,
Satheesh
Dec 29, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
Hi, how can i reset my password on the zyxel router I forgot it
Dec 28, 2010 | Zyxel Prestige P-330W Wireless Router...
Pin number was forgot
Nov 14, 2010 | Computers & Internet
Forgot my password
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 06, 2010 | Linksys Wireless-G Broadband Router
Forgot password and user name??
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you want to secure wireless then enable WEP in wireless security enter password there it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 05, 2010 | Linksys Wireless-G Broadband Router
I forgot my security password (ecryption key) of my WRT54GS. As a result I cannot login my laptop to the internet. Whay can I do next? I do have my original Lynksys CD but I use a IP phone connecting to...
You need to go into the wireless router settings, if you cannot see the encryption setting the you need to create a new encryption key and the configure the laptop's wireless card with the new encryption key so it can connect to the wireless router and Internet.
Oct 10, 2009 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
