Question about Rheem Fury 38 Gallon Low NOx High Efficiency Natural Gas Water Heater
Change thermocouple on rheem 22v40fn
I have no hot water. I want to know how to change the thermocouple on this waterheater
  • 234 Answers
SOURCE: I have a Rheem EcoSense hot water heater and all
Have you try to reset the power to the heater?Then turn the hot water facuet on to see if it will start up.
Posted on May 02, 2009
co7196
  • 3433 Answers
SOURCE: can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Posted on Jun 15, 2009
  • 1015 Answers
SOURCE: Where can I purchase a thermocouple for a Rheem 50
I think you can use any standard thermocouple of the right length. These are available at most hardware stores.Thanks
Posted on Nov 23, 2010
heatman101
  • 43501 Answers
SOURCE: Hi! i have a rheem 82V40-1 WATER HEATER THAT WON'T
The heatings elements go bad and or the thermostat can also go bad...check also that the reset did not kick out...
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Posted on Apr 04, 2011
SOURCE: Believe I need to buy
If thermocouple is from ordinary tank-type water heater, then it is a generic part with different lengths 15" 17" 21" 24" 30" available at hardware of home center.
I suggest reading manual for installation information, advisories, and required maintenance.
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
There are good utube videos on replacing thermocouple.
Tip of thermocouple has to be positioned in the pilot flame.
The heat on tip of thermocouple causes millivolts of electric current that travel back to the gas control valve and the electrical signal causes gas control valve to keep gas flowing down the pilot tube to the pilot light.
If pilot light blows out or if pilot tube is clogged and needs to be cleaned, or if gas valve has gone bad, then tip of thermocouple cools down and electric signal back to gas control valve causes gas control valve to shut off gas going to pilot.
When attaching thermocouple to gas control valve, it is finger tightened.
Be careful and do not cross-thread thermocouple. Just use your fingers to start the nut.
Finger-tighten thermocouple and then add 1/4 turn using small wrench.
The end of thermocouple has a small piece of insulation that isolates the electric current from body of gas control valve. If thermocouple is overtightened, the insulation is crushed, and electrical current millivolts short out and no signal reaches gas control valve, so gas control valve keeps gas turned off to pilot tube.
If this is a tankless water heater, then open following link with troubleshooting resources and contact information for Rheem.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 20, 2011
Home water heater no hot water
Electric water heater?
Open top cover and push in reset button.
Check circuit breaker.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gas water heater?
Use mirror and peer upward through sight glass to see if you have pilot flame, and that flame is clear blue.
Clean air intake.
Change thermocouple.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Tankless gas?
Call service technician.
Oct 29, 2012 | Rheem Water Heaters
How to how to install the anode rod - for extended warranty - in a new Rheem waterheater?
You are installing a combo anode rod that replaces hot water outlet nipple. This means you will have 2 anode rods, which doubles the anode capacity of tank, which can cause extended life of water heater, assuming that both anodes are inspected each 2-5 years.
Sounds like a heat trap insert is in the way.
Look at parts sheet that comes with product manual.
Pull insert out since it will cause clogs.
Same insert is on cold side nipple.
I want you to contact the Tank forum since they are anode experts:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Tank will recommend magnesium anode and not aluminum.
My understanding is that Rheem water heaters are made so only Rheem brand anodes fit their tanks. While other companies use generic anodes that are sold at any plumbing supply, and also sold at Tank website.
You can configure pipes to make heat traps that save save $2-4 per year on gas water heater operation.
http://waterheatertimer.org/images/Heat-trap-install-900.jpg
http://waterheatertimer.org/How-to-maintain-water-heater.html
Sep 08, 2012 | Water Heaters
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Sep 14, 2011 | Rheem Tankless Hot Water Heater...
Model #22v30FN serial# rhu08898u6983 mfg date 20 aug 2009 waterheater won,t light (installed sept 2009)
Gas water heaters are a huge field:
More information is needed for correct do-it-yourself answer. Add a comment and include what steps you have taken and what you observed at the pilot light. Include description of gas control valve.
The combustion parts may need to be cleaned, the thermoscouple could be bad, misaligned thermocouple, the system locked out from FV flammable vapor event, or overheating caused ECO energy-cut-off to trip, or air in gas line, low gas pressure, or dirty air intake, bad venting, improper venting, bad gas control valve, negative pressure, tight house, lack of combustion air, hot attic, exposure to chemicals in air, rusted parts, etc.
Add a comment any time.
Or contact Rheem at 1-800-432-8373
Or continue reading to find correct resource:
You have Rheem 30 gallon ultra low-nox gas water heater.
Knowing the gas valve is necessary for troubleshooting.
The 40 and 50 gallon version of this water heater have electronic self-diagnostic gas valve as shown on following link.
http://www.rheem.com/product.aspx?id=F4AE5B83-899F-4AC0-B09D-22A6770BE799
Open following link to identify gas valve, then add a comment and describe which gas valve you have.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Open following link for general do-it-yourself resources, with reading resources, service manuals, images that illustrate cleaning and different gas water heater parts
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Add a comment for more help.
Take a moment and rate answer for accuracy:
Sep 13, 2011 | Rheem Water Heaters
I can not light the pilot on my reliance sta-kleen 502 (30 gallon) waterheater. please help
Reliance is Rheem
Replace thermocouple is best start point.
Example Whirlpool manual shows general replacement steps on page 22:
Buy thermocouple at hardware or home center. measure length before going to store.
http://waterheatertimer.org/pdf/Whirlpool-6510397.pdf
Utube videos show how to replace thermocouple
Many things can affect pilot:
Low gas pressure, Water or air or debris in the gas control valve, High-heat event causing ECO to trip requiring new gas control valve, burner and tubes needing clean-out, FV sensor tripped, loose or bad thermocouple.
Manual above shows general steps for doing some of these things, but service technician is probably best choice if thermocouple does not fix problem.
Gas water heaters require periodic maintenance.
If repairs cost more than $330, then buy new gas water heater and install yourself.
Use the old one for a solar collector.
Upvote the help.
May 22, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Rheem PG50T9A gas hot water heater. We had hot water this morning. When I came home the pilot light was out and won't stay lit. Any ideas?
Hopefully just the thermocouple. The thermocouple is the small rod right next to the pilot light. The flame on the pilot heats up the thermocouple and keeps the gas valve on. You can replace it yourself. The thermocouple will be connect by a small nut on the underneath side of the valve, and you will have to pull the thermocouple out of the pilot assembly. Not an expensive part, you can get it at any hardware store. Hope this helps you .
Apr 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
My Rheemglas fury 21DV50 hot water heater pilot goes out about every 2 days for the last week and 1/2. It will light and I'll be able to have hot showers but doesn't last more than about 2 days. Is it the...
It could be a thermocouple but first take the whole pilot assembly out and disassemble it. Clean it very good (compressed air is ok) especially the orifice inside the pilot horn. You may just have a weak pilot. If the flame is in good contact with the thermocouple and problem still exist, then change the thermocouple. I believe in doing the free things first.
Jan 28, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Can no light up a new Rheem 22V40FN water heater
Jun 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem Fury 38 Gallon Low NOx High Efficiency Natural Gas Water Heater Logo
604 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
