Why will my laptop loose power then when been left works until u leave the screensaver to go on then I cannot get anything bk on screen what dose the home button with systq under it do
    New Friend:
If you don't want your computer to go to sleep due to inactivity go to power options from the control panel and select high performance (found in additional plans)/
Posted on Dec 07, 2012
4 Suggested Answers
Drachnem
  • 34 Answers
SOURCE: laptop wont tart
I would like you do reseat (take out and reinstall) the following:
Memory Battery
Next I would like you to verify that the powercord is still working, when you plug the cord into the laptop it should light up on your laptop, and there may also be a power indicator on the powerpack itself.
After you have done the following please post back here and let me know your findings
P.s. Note any beeps and sequence when/if they do.
Posted on Jan 19, 2009
mraviteja
  • 51 Answers
SOURCE: HP dv9208 pavilion laptop screensaver & briefcase not working
Hello there
Call HP or go to chat support and threaten them that if your Notebook wont be repaired you will go to consumer court....
HP's 24X7 chat support...
http://welcome.hp.com/country/us/en/contact/chat_1.html
Posted on Feb 18, 2009
digecorp
  • 92 Answers
SOURCE: My left click button on my touch pad of my hp
Ask HP for the part's list+diagram for the laptop. It should show you what to tae out and where the screws are.
Posted on Apr 11, 2010
Restore toolbar. It did not return when screensaver had been showing and I tried to get back to work again.
Do a hard re-boot, hold down the power button until the lap top turns off. Then re-start and check to see if everything is ok.
Mar 03, 2015 | Dell Inspiron 1100 Notebook
Screen goes blank
This is most probaby because of a loose display cable connection .As the cable runs through the hinge slot to the mainboard of the laptop, open the laptop full and try pressing carefully on the left side of the laptop near the hinges area. this should give you the display back.
Mar 18, 2014 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I left my PC and monitor powered on and when I came back, no display.
seems simple enough, go into your computer power settings through control panel and turn off standby mode as well as hibernation. set it to be on all the time. if you're using the syncmaster i assume you're talking about a desktop computer and not a laptop, if that's the case and the syncmaster is lcd, then you don't really 'need' a screensaver but if you want it to hide your desktop while you're not there you can add a screensaver for fun :P
Jul 02, 2012 | HP Computers & Internet
How do I get my laptop out of hibernation?
right click desktop screensaver settings power settings or control panel.
Oct 24, 2010 | HP Pavilion dv5-1000us Notebook PC
How to stop my laptop from turning off when I am watching or reading something
1. right click on an empty spot on your desktop-select properties. select the screen saver tab-using the drop down arrow by the screensaver box change the screensaver to "none", click apply.
2. while at the screensaver tab, click on the "power" button- click on the down arrow on the right side of the Power Schemes box and select "always On"- click APPLY and OK
This turns off your screensaver and power management for continuous play of dvds or extended reading time..
you will have to yurn off the monitor manually if you leave the computer running all night as it wont auto powersave now...
Regards
Jun 28, 2010 | Samsung R530 Notebook
I accidently uninstalled acer screensaver on my acer aspire laptop and it removed my hibernation mode also i want it back, please
You can right click on any open area of the desktop to get display options. Find the screen saver tab and preview the screen savers until you find the one you lost. Once found apply it and click ok. Then go to start or windows icon in bottom left. Then select control panel wint he windows utility menu. Once there go to performance and maintenance. select power options and adjust acordingly. Good Luck
Nov 22, 2009 | Acer Aspire 5315 Notebook
Hello there
Feb 18, 2009 | HP Computers & Internet
Hp Pavilion ze2000
if it is not the graphics card then it sounds like dead pixels on the screen there is no way to fix the screen without replacing it :)
just mess with it though. squeeze the screen by pinching it on the outsides gently and it might go away or wiggle your monitor back and forth. because maybe you just have a bad connection...
oh and do you leave the laptop open and on all day without a screensaver? If so the image has probably burned into the monitor. You should apply a screensaver straight away to avoid having to get the laptop replaced, happened to me with my last monitor, I learned the hard, €200 way!
Good Luck!
Dec 01, 2008 | Computers & Internet
Screen saver no longer works
Well, you have two options to look at:
1st one:
Since your laptop is Dell, I presume that you use Dell Media Software.
Other people had the same problem too. Try disabling this program to check if your screensaver is working.
Other programs that might conflict with the screensaver might be:
1. Ehtray.exe.
2. DVDLauncher.exe
3. Power DVD
4. PCM service.
Otherwise there is a known bug:
Try updating (flashing) the BIOS with an updated version. This seems to be a problem Dell was aware of an made available a "fix."
How To:
http://support.dell.com/support/edocs/sy...
Download Location:
http://support.dell.com/support/download...
Hope that helps,
TrustMe
Apr 15, 2008 | Dell InspironTM 1501 Notebook
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
