Question about Craftsman Garden
Bought a new Craftsman Rear Engine Riding Mower and the bagging attachment. I realize you must have a good connection at the deck chute or the lawn mower won't start. We can get the mower to sta
30 inch mower. Model no. 247.25000
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
  • 3 Answers
SOURCE: Need image, assembled craftsman model 917.276813 lawn mower deck
http://afternoon-tea.bordadom.vu.cx/index.html italian wine bar
[url=http://afternoon-tea.bordadom.vu.cx/index.html]italian wine bar[/url]
<a href=http://afternoon-tea.bordadom.vu.cx/index.html>italian wine bar</a>
Posted on Aug 26, 2009
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
What is a 2001 17.5 Craftsman riding lawnmower worth 42 inch cut?
Condition makes a big difference. Common defects noted when selling a mower are: seat is ripped up; hood is off; needs a deck or drive belt; needs a battery; discharge chutes broken or missing; or the engine smokes when running. If the mower runs (can be jump started) but has some or all the problems it should range in the $150 to $350 price range. If it doesn't run or will need repairs just to get it to mow the $150 is about all you should expect. If the paint is good, stored inside and deck cleaned after uses and doesn't have the problems and is in good shape, a mower of this age can bring $500 to $750. The more problems the lower the asking price should be. Another factor that can determine value is where the mower is at. The price of a mower in California may bring more than one in the mid west - supply and demand.
May 27, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Deflector installation
Where does it go the mower deck or the engine. On a John Deere rider like we have , it goes on the mower deck that is located under the tractor or mower. On the right side ( when sitting on seat) ours is on the right and it is for the bag or box attachment for clippings and or debris. A plastic cover is held on by a short rubber bungie on each side that as a hook on each end and it hooks around a small bracket to the front and a small bracket to the rear...Do you still have owners manual ?. most guys keep them in some drawer or shelf in the garage or tool shed area ...good luck...
Jun 05, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a diagram showing how the throtel cable attaches to the carb on a Craftsman 17.5 hp, 42 in.,riding mower (NEW 2008)
The throttle cable doesn't attach to the carburetor. The 'z' bend in the end of the cable sticks in the white plastic slide at the bottom of the control plate on the left rear side of the engine and the cable is held in place by a clamp behind it.
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
