JVC LT-42da8bj my hdmi portare not working need to do factory default setting
  • jonaid Dec 06, 2012
    i need to know how to do a factory default so things can go back to the way they used to be.. i am hoping this will solve the problem.. right now all it dos is shows blue screen and for few seconds the screen get black as if it was trying to connect to the hdmi device but failed to do so.. any help would be good regardsjonaid
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
SOURCE: JVC LT-42DA8BJ
How are you connecting your laptop to the samsung TV? Is it DVI/HDMI or thru more-common S-video cable? I have successfully ported laptop screen to TV with S-Video. After you connect your S-video cable, right-click on blank desktop of laptop and bring up the Display Properties (usually the last entry on pop-up menu). Got to last tab, usually called Settings. You should see two monitors displayed on top part of this page. One of these (most likely #2) is your TV. Click on #2 monitor and check the box that reads "Extend my Windows desktop to this screen" (or words to that effect). Be sure you have the TV turned on and facing you because you may find yourself clicking on icons on the TV screen. You'll probably have to play with which is primary display because some video players have trouble playing to a secondary screen. You may also try the Fn+F8 (CRT/LCD) button on your laptop (those are the keys on my Dell). That may turn on the TV-out on the laptop. Lastly, remember that this will only get you video. You'll have to connect a 3.5 mm cable to you Line-Out port on the laptop and connect it somehow to your TV or SurroundSound speakers. There should be a audio-in port on those other devices for that. Or you can just play the sound thru your laptop speakers.
I'm not that familiar with the DVI-out but I suspect that it would work very similiarly. Good luck.
Posted on Jan 25, 2010
e-Guru
  • 3917 Answers
SOURCE: I Own a JVC LT-420T82J
Hi
There is a sensor inside the set that disables the hdmi ports if a certain procedure is not followed. When the set is put into shipping position this should be reset. The procedure is to manually disable/reset the sensor.
1. press "mute" and "info" button at the same time to enter service menu.
2. press "1"
press the "down" button until you get to F002
press "vol up" button to change from 0 to 1
press "ok"
press "back"
(if you go right out of the service menu here just press mute and info again)
3. press "6"
press the "green" button until you get to FF30 (about 13 times if skip it by accident u can use the red button to go back the way).
press "up" button twice to highlight 01
change from ** to 00 using "vol down" button
press "mute"
press "back" twice. This steps should do it.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 14, 2011
  • 127 Answers
SOURCE: 32" JVC LED TV will not play SKY+HD through HDMI
You need to select HDMI input.
Posted on Nov 01, 2012
  • 1253 Answers
SOURCE: JVC LT-42DA8BJ When playing my ps3 in hdm1 port everything is fine execpt the hdm1 e4 720p logo in the corner of the screen won't disappear. I also cant find the remote however if the only fix is on
I believe that is the display or exit button.when you find the correct button, the display will cycle through a few formats and then disappear. JVC is a lot like Sony in that you better never lose your remote control.
Posted on Jan 11, 2015
JVC lt-42e478 HDMI No Program or Weak Signal, AV works {blurry and oversize}
Nope sorry this does sound like your control board is naffed and needs replacing , it sees the avi as no rf input is needed but will not switch to if to give you vision chroma and sound .
Jul 02, 2015 | JVC LT-42E478 42 in. LCD Television
JVC LT-42DA8BJ When playing my ps3 in hdm1 port everything is fine execpt the hdm1 e4 720p logo in the corner of the screen won't disappear. I also cant find the remote however if the only fix is on the...
Jan 11, 2015 | JVC Televison & Video
TV is just over one month old - screen started getting darker and darker in pathes, now more than 60%, tried resetting all settings to default, tried all inputs (Video, HDMI, RF) all the same result -
Return it to your place of purchase and get something else anything else you wouldn't believe how many people are having Issues with the LT series get rid of it.
Jun 29, 2014 | JVC LT Televison & Video
JVC hdmi not working
Check the HDMI settings.
Mar 17, 2013 | Televison & Video
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
JVC LT-42DA8BJ
unable to get laptop image on samsung lcd tv. Can anybody post some clue please
Oct 27, 2007 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
