Question about Rival Crock Pots & Slow Cookers
I accidentally set my crock pot on warm instead of low for 9 hours with stew meat and veggies in it. ok to cook on high for some hours and eat it?
Will the food be safe to eat if it's cooked on high for several hours more?
  • 2926 Answers
SOURCE: i accidentally cooked raw chicken
I would not chance it. The meat has never been brought to a hot temp that would kill any bacteria if bateria were present. Throw it out; for the cost, it is not worth the risk.
Posted on Jan 09, 2011
  • 12 Answers
SOURCE: Cooks too hot
It would SEEM that this pot has a nanufacturing problem, where the thermal switches, that actually cycle the unit off when it reaches a certain temperature, are faulty...right from the factory. Its common to get a run of faulty thermal units, and is often seen in Coffee Makers.
Posted on Jan 25, 2008
  • 52 Answers
SOURCE: How to cook beef stew in rival crock pot model
check the internet for a copy of the manual. Put in the search engine rival crock pot and look till you find a free manual then you can down load it and print.
Posted on Oct 22, 2009
  • 59 Answers
SOURCE: My Rival Crock Pot seems to cook a lot faster than
Probably, nothing. About 6 years ago the standards on these were changed, to increase low to 200 degrees instead of 180, high to 300. Things that took 6 hours can now take 4. If you are using older recipes, or recipes perfected in older pots, they will always overcook. You can check this by putting water in, covering, and checking with an instant read thermometer after 1 hour. If it is 200, there is nothing wrong with you or the pot.
Posted on Nov 25, 2009
Testimonial: "This makes a lot of sense. I am cooking a pot roast right now and reduced the time by a third so I'll see if that will work. Thank you."
  • 56 Answers
SOURCE: On a Rival crock-pot, which is the higher cooking
Low and High are cooking levels, warm is to keep the food warm after it is cooked.
Posted on Mar 15, 2010
Testimonial: "That's exactly what I needed to know. Thanks for such a prompt response."
Stew was supposed to cook for one hour. Not close to done. Still on but no idea how long it will take. Was set to slow cook as recipe said.
When you use a slow cooker, you must either boil the food before adding it to the slow cooker or add an hour to the cooking time to bring it up to a simmer. That is the time that the cooking actually starts to make the meat tender. Stewing beef would take at least 2.5 to 3 hours. The only way you would do it in an hour is you used fillet steak.
Feb 07, 2016 | Crock Pots & Slow Cookers
Vegetables take hours to cook. Something wrong??
what do you have your setting on the crock pot for maybe you need a higher setting for them.
Mar 11, 2013 | Rival 38501 Smart Pot 5-Quart
How long should i cook on high a full crock pot with vegetables and raw meat
when do you want to eat? It usual takes a good six hours on high.
Dec 31, 2012 | Rival Crock Pots & Slow Cookers
Do I put stting on HIGH or LOW when cooking a stew etc:
It depends on how fast you want t ready to eat. Rival recommends low for 8-10 hours or high for 4 or 4 1/2 hours. Hope that helps you.
Jul 08, 2011 | Crock Pots & Slow Cookers
What is the temperature setting "warm" mean on a crock pot? My sister accidentally left her meat on "warm" rather than "low" and needs to know if it is safe to eat. I told...
Warm will keep food warm safely for a few hours after it has finished cooking. If this happened after a regular cooking time it is OK
Jan 31, 2018 | Rival 5070 7-Quart
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
I accidentally cooked raw chicken all day on warm instead of low....is it still ok to eat?
Jan 09, 2011 | Rival SCV702 Slow Cooker
Hi i have a hamilton beach crock pot that only has low, med, and high to cook with. i cannot find my book that has the times or what to put the crock pot on for port tenderlon and how many hours to cook...
Most recipes will have different times to cook meat, I would make good use of www.google.com and look at recipes and suggestions there. Generally speaking I would say you're going to cook that on low for about 4 hours, but it really does depend on the amount of meat you're cooking and your personal preference.
Dec 08, 2010 | Hamilton Beach Crock Pots & Slow Cookers
Whats the differences with the low high and auto settings on a slow cooker which setting is considered best for cooking stews
The difference is the time and how warm it cooks. Low cooks a slow, lower heat - cooks 6-8 hours. And High is a faster cook at 4-6 hours. I tend to use low for stews and chilis.
Feb 11, 2010 | Crock Pots & Slow Cookers
Why does my crock pot cook at too high a heat?
With something that small, there is not a lot of resources for parts and repair. The item is considered a throw away. You could contact customer service at RIVAL and see what they say about the issue. Could be mis-wired or something like that. The only easily replaced part for that is the stoneware.
Jun 16, 2017 | Rival Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
801 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
