1995 Isuzu Trooper Logo
Posted on Dec 06, 2012
Alternator wiring or connection
For rewiring
Charging system on a Duetz F6L912
if it is a single phase generator then the 3 wires/terminals will be active --neutral and earth. The melting wires is an indication of a real problem that rewiring is not going to fix properly. If the wires are melting ,then that is an indication of excessive current draw or dead short somewhere and I strongly advise to have it checked out by an accredited electrician before you do anything.
I have a 1994 p30 stepvan that has been altered i had to put a 85 catalac alternator now i cant get it wired up the alternator plug was cut off and i dont no how to rewire it
You need wiring diagrams--- do you not
No one on the internet worldwide & this is just
a social web site --will be able to help,sorry
I need the wiring diagram. I'am doing rewire on a 66 Chevy truck to a one wire hook up. I have anew pigtail plug with the excitor wire anda short wire lable alt barttery with a1/4 lug on it. Do you puy...
The red wire goes to the lug on the back of the alternator (B+ connection) You need to run another wire from that terminal directly to the battery. Normally, the remainder of your power accessories will be attached to the starter main terminal but you could run that from the battery as well since that's the other end of the same wire. I wouldn't use the alternator terminal for that only because the insulator on the terminal could overheat and melt if overloaded for any reason. In any case, everything except the wire between the battery and alternator should pass through the ignition switch so it's all off when the key is off.
A. Power Issue: The battery does not hold a charge due to over-amping. Causes: a) the alternator is rated for industrial work; b) it has specific wire gauges for the alternator circuit. Repairs for this...
a bad alternator can over charge as well as under charge - suggest getting a second opinion elsewhere - as far as alternator being "too big" - it will only give the battery what it needs when it is working properly regardless of size
2answers
Alternator wire that runs to the fuse box melting.
if you have a salvage yard near you go there and find a durango with the same engine as your cut those wires of and your and then rewire it look at the dodge rams as well.
1helpful
2answers
1981 ford truck alternator schematic
replace an alternator on a 1981 ford f-150
1helpful
HOW TO REWIRE THE ALTERNATOR AFTER WENCH REMOVAL
why the big deal two wires and a ground run to altenator small wire connector is the warning light and the big connector goes to the battery or the battery /starter connection and thats it winch has nothing to do with anything regarding charging,it will be connected directly to the battery.
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
