Question about Seth Thomas Pacconi Turntable
Need instruction booklet for a Thomas Pacconi 1900-2000 Classics turntable/cd player/ tape player am/fm radio
Want to turn tapes in to cd's
4 Suggested Answers
SOURCE: Thomas Pacconi turntable turns too slow
I took it apart and the belt was off where it needed to be
Posted on Dec 29, 2008
  • 3 Answers
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Posted on Jan 21, 2011
BAMOUT
  • 2478 Answers
SOURCE: power supply for a thomas pacconi model tpc-hd-12 ser number 060800521
These people may help you.
www.turntable-power-supply.com
Posted on Nov 28, 2011
A lot of my buttons don't work, could they be dirty? How do I clean them?
Servisol video 40 can be used to clean buttons and controls.
Jan 02, 2013 | Audio Players & Recorders
I put a tape in and it keeps flipping sides without playing and pops out and says Error. It even does it with a CD-Cassette Adapter. Before the Cln came up and I pressed on the eject button and that...
Cassette decks have sensors on the reels which tells the deck when the tape is at the end. When the reel stops the deck switches the direction of the tape and sometimes the position of the head(depending on the deck design). Most common problem is the tape is hard to turn, or the deck won't turn it ( deck thinks it's at the end, click, still won't turn, click, won't turn, click) you should fast forward and/or rewind your tapes from start to finish once in a while to keep them lined up(narrow spool/less friction), you shouldn't have to but it works. BUT,...your problem sounds like a slipping or broken belt/or dirt causing the problem. Take the deck out to have a look and clean the capstans(rubber rollers)belts,heads with alcohol and a Q-tip while your at it. Dirt's usually the main culprit and if you do have some other problem, cleaning it is always a win/win (It will also sound better clean)
Sep 20, 2011 | 1995 Buick Regal
Sharp CD-BA2100, when I turn it on it starts making a clicking sound and if set to tape one or tape two, it shows "error". When set to "cd" it comes up with error 0306 and the cd tray...
the rubber rope which conect the motor to a small gears to open the cd was cut due to long using ... this sound of clicking coz the small motor is running and its not attached to anything ... its a small rounded rubber rope ..the bad news is you have to break some plastic stuff to reach the motor in the repair depot they change the whole upper part so it costs alot ... but if you can reach it it will work perfect as its new.
Sep 08, 2011 | Sharp CD-BA200 CD Shelf System
Cd in macbook wont ejec
This can be a problem. First try rebooting the machine, and holding the eject button when you hear the startup tone. Hopefully, that will force-eject it.
If that doesn't work, you'll need to get creative. Get a playing card or something similar, and put some rolled-over tape on one side close to the edge, so there's a sticky side out. Turn the computer off, and try to get the playing card into the CD drive, with the tape making contact with the stuck CD. Reboot, holding the eject button when you hear the eject button again, and pulling the card out. Hopefully, the CD will come out with the card. If it doesn't work, just keep trying, and you'll get it out eventually.
Generally what causes this is keeping CDs in the computer for an extended period of time, especially while the computer is powered off. Make sure you remove all CDs before moving or turning off your computer.
Sep 07, 2011 | Apple MacBook Laptop Computer Mac...
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
Aug 22, 2011 | Technics SH-GE70 Home Equalizer
How do i turn off the eject for my tape deck on a 93 acura ledgend?
Well my friend, as good as Honda is for making the Acura line, even a good thing goes bad sometime. I am going to make a recommendation that I'm sure you have heard before, time to get a CD player. CD players are so cheap now, you can get one for $50 and the harness to install it for $10. The harnesses for that make and model is very abundant, so you shouldn't have trouble finding the parts. If you are a tape buff, and just can't give up the 80's and 90's originals, get a unit with an auxilarry input and plug a portable tape player into it. Why not, it's just sending signals anyway. Happy Hunting
Aug 13, 2011 | Car Audio & Video
How do you get to the head to clean it?
Google for CD/DVD cleaners and VHS cleaners. A CD/DVD cleaner is like a CD, but has a small built in brush that'll clean the laser head. A VHS cleaner is like a VHS cassette tape, but instead of magnetic tape, it's a cleansing tape.
Jul 18, 2011 | GoVideo DV2150 DVD VCR
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
I have a tape which I'm anxious to play to convert to a CD, but it just won't play ! It will fast wind both ways but on play just shuts off. (It hasn't been played for a long time) It does...
If you wind the tape by hand (with a pencil or screw driver etc.)is the tape easy to turn or move from one end to the other with out any binds? If not It may be wound unevenly, smacking it down on a flat surface a few times on each side will usually free it up. Hope this helps.
May 17, 2011 | Audio Players & Recorders
How do you record onto a tape from a CD?
I couldn't find the exact manual but the XL-HP505 may be close enough...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sharp-XL-HP505-manual/id/285dj790/t/2/
Apr 27, 2011 | Sharp XL-HP500 CD Shelf System
Seth Thomas Pacconi Turntable Logo
245 people viewed this question
Top Seth Thomas Audio Players & Recorders Experts
Dennis Key
Dennis Key
Vito Vacirca Jr.
Are you a Seth Thomas Audio Player and Recorder Expert? Answer questions, earn points and help others
