Question about Peg Perego IGED1084 Santa Fe Train
Motor problems peg perego Santa fe train
Still not working with new battery. How to make sure it is all connected correctly or if I need a new motor
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Use a multimeter and check to see if you are getting power at the motor, you should be getting at least 6 volts
Posted on Dec 07, 2012
2 Suggested Answers
  • 156 Answers
SOURCE: My son poured water in his peg perego santa fe ride on train
It might have shorted out the motor under the seat.
I would contact the repair help at
http://www.shopjandl.com/
Posted on Jun 23, 2009
How to fix the battery charging system
Are you saying it cranks good but won't start? If so, have a helper crank it while you visually check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure. Also, check fuel injector pulse.
If the starter motor won't even crank, then have to check starter motor wiring circuits for voltage and ground. Any testing at starter, make sure tranny is in park or neutral and the parking brake is set.
I'd have to test to make sure battery and connections plus the charging system are working correctly, even if the parts are new.
On some makes and models if battery voltage is lost, there may be some modules that need to relearn or be reprogrammed before systems will work properly. Also, check your security system. Are there any applicable trouble codes?
Dec 04, 2015 | 2011 Chevrolet Cruze
Battery or motor?
check the battery and the charger with a multimeter and make sure they are showing the correct volts, and then check the voltage wires where they connect to the motor and see if its showing the correct volts there when the foot pedal is pressed
Jan 17, 2014 | Peg Perego IGED1084 Santa Fe Train
My alternator wont charge my battery. both are new, new fuses, and wires and cables
Hi Paula, As both the battery and alternator have been replaced, there are only few remaining reasons why the alternator will not charge. Make sure of the socket connection being fitted correctly and that there is a good connection on each of the connectors inside the connector. Check and make sure the earth earth connection between the battery and the engine is correct and that both ends are tightened correctly. Inspect the 'Alt' fuse in the fuse holder and also the fusible link. Also make sure that the belt is tight. Regards John
Jan 27, 2013 | 1990 Toyota Camry
We've got a santa fe and the sound button is working but the train doesnt move
sounds is run by 3 aaa batteries under the smoke stack and train is run by 6v battery under the seat, 6v battery probably need to be connected or recharged
Jun 06, 2011 | Peg Perego Santa Fe Express Ride On Train
Put new battery in a month ago, now when i turn key on nothing happens, no dash indicator lights come and nothing happens when key is turned on
Possible errors are either incomplete or non-load generator ground connections between the engine and car body.
Mar 04, 2011 | 2003 Chevrolet Silverado 2500HD
Tailgate power window not working
Check to make sure you have battery voltage at tailgate power window, make sure you have a proper ground also. manually run a hot and a ground to the motor to see if it even works, if it does then you know your wires aren't properly connected. If the motor doesn't work then you'll need a new motor and possibly a new regulator, the cost for this would be around $300 or more. Hope this helps you out. Have a nice day! :)
Oct 27, 2010 | 1996 Ford Bronco
Power problem
i would start by checking all the fuses first then make sure the battery connections are on correctly and are also clean and tight, you may have a bad starter but you should be getting power to headlights and dash lights, if theres no power anywhere but the rear door then theres a bad fuse somewhere, but if the headlights work and brake lights and dash lights and the heater blower motor all work then you may have a bad starter, make sure to have the key on when checking these things.
Jul 13, 2010 | 1993 Mazda Protege
Santa Fe Express Train not working
check the charger first and make sure that it isn't bad, you can check it with a multimeter and make sure that its putting out at least 6 volts
Apr 19, 2010 | Peg Perego Santa Fe Express Ride On Train
Peg Perego IGED1084 Santa Fe Train Logo
139 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
