I was Samsung washing machine model number WF218ANW/XAA It's making a flapping sound in the back during a spin cycle.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 55 Answers
unplug and re-plug the Washer and check if the issue persists. otherwise click on this link for chat support http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=346139&modelname=WF218ANW&modelcode=WF218ANW%2FXAA&session_id=QBLGXKdDpFv5J32LF2rR81JCHqnryJpb6V1ldwQh6Wt1RQfLhRQy%211780044318%211589942691%211354844292695&from_osc=#
Posted on Dec 07, 2012
I just chatted with Samsung support on this exact issue and this is the response that I got:
"I have checked the information for you and see that there is no option to stop the flapping noise."
Literally. That's it. Nothing. No help whatsoever. No creative ideas, not "really sorry" nada. Pretty annoying.
Posted on Jan 25, 2014
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Posted on Feb 17, 2008
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
  • 291 Answers
SOURCE: washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Posted on Feb 16, 2010
I have a Samsung front loader washer wf419aaw/xaa. 2 days ago it started making a loud knocking sound during the spin cycle. The drum also feels loose. I have researched every site I can find but still...
it is best if you engage the services of a technician. While it could be bearings ( I doubt it ) it is most likely something between the wash drum and the outer case that is hitting during spinning. something like a ( from hosier)y wire, bobby pin, button, coin
Feb 12, 2015 | Samsung Washing Machines
Wf218anw xaa
Are you trying to run a 50 hertz machine on a 60 hertz line?
Jan 12, 2014 | Washing Machines
My Samsung WF218ANW/XAA front load washer will not drain & the display reads "nd". I have already drained the water through the front panel tube & have cleaned that filter, washer still...
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Jan 22, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
How do I replace the oring gasket on a front loading samsung wash machine model number wf219anw/xaa
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Aug 11, 2010 | Samsung WF337AA Front Load Washer
WF218ANW/XAA not accepting cold water, only hot?
Hi you most likely have a bad water fill valve.
part # "dc62-30314k"
This is a common failure on all washing machines.
If I can be of further assistance please let me know.
Mar 18, 2010 | Samsung Washing Machines
Samsung washer wf209 makes vibration like noise from pump when starting spin cycle
pump clogged. Remove clean out from pump and then remove any debris inside.
Jan 31, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
The laundry is still wet after a normal wash cycle, because the machine doesn't get into the "high speed spin" (this has happened several times . . . have only had it 2 weeks). It has happened on full...
Since it can spin by selector then there is no problem with the spinning mechanism. Need to call warranty service to address the electronic sensor control.
Jan 09, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
WF218ANB noise like a bag of rocks being shaken.
This is a direct result of Samsung's Vibration Reduction Technology(VRT). There is a hoop at the front and the back of the drum holding 18 ball berrings in each hoop (36 in total). These balls use centrifugal force and automatically move to the opposite side of where the load is unbalanced and balances it out. It is only in the washing machines, not dryers.
Dec 16, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Washing Machines Logo
731 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
