Question about ASUS Eee 4G Notebook
The screen display doesnt fit the screen, i have windows xp installed, and under properties the slide bar wont move so therefore i cant adjust it. help?
    Problem Solver:
  • 5 Answers
At a guess, you do not have the proper VGA drivers installed.
Official Downloads:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Go into Start -- Control Panel -- System (Classic View) -- Hardware -- Device Manager Tab.
Click on Graphics Card and uninstall and reboot.
For alternative drivers, Run a search on
http://www.eeeuser.com/
Posted on Jan 12, 2009
How do i align my computer screen to fit my screen
Align my computer screen to fit my screen?
I think you are saying that what is displayed on your screen is not aligned and you can't see everything.
Try adjusting your screen resolution. Click Start/Control Panel and look for Display or Appearance and Personalization to click on. You might can just Right Click on a blank area on the display screen and select Properties. Once you get the Display Properties to open select the Settings or Resolution tab. Adjust the screen Resolution by sliding the bar over to the right. The higher the resolution, the smaller the icons, thereby the more will fit on the screen.
May 13, 2012 | HP Computers & Internet
My computer's screen resolution is too low
Hello to adjust your screen resolution, right click on the desktop and either click properties for Windows XP or screen resolution for Windows Vista/7. Then for XP click settings and you will see a slider bar where you can adjust your screen resolution. For windows 7, it will be on the screen that opens up, just slide the bar into the resolution you want.
Thanks for using FixYa!
Aug 15, 2011 | Computers & Internet
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
I accidently changed my desktop screen size, how do i go back to default settings. my screen is so small windows dont fit. i was trying to make my icons smaller and i accidently made my screen size...
In Windows Vista, right-click on an empty spot on the desktop, choose Personalize, choose Display Settings, adjust the Resolution on the sliding bar. In XP it's similar except you choose Properties instead of Personalize. I don't have XP in front of me right now. :)
Apr 29, 2010 | Compaq Presario Notebook
I bought a computer gateway dual core and I plug it to a CRT but the image that is displaying is not complete is like the screen does not fit the monitor how can I setup to get the complete image on the...
control panel - display - settings There is a slide bar on the lower left. slide it to the left and click apply. That will change the size of the display so all you need to do is find out what you like or what the 'native mode' is if you have a lcd monitor. That is the display size it want to have and should be show in the manual.
You may also want to click on advanced which will be to the right of that slide and then makre sure the display adapter has the right drivers. You may want to download and install the drivers directly from the manufacturers website. sometime windows update will install a update and it just doesn;t quite work so best to get the one from the factory if that is the case. Also make sure the monitor is in there correctly. Most major brands will let you download a inf file and make sure the only selections available are those that the monitor can safely handle.
Mar 23, 2010 | Relisys CRT TE786H 17 1600X1200 0.25MM
The text is too tall and not wide enough. How do i adjust the monitor?
If you are using Xp right click on a blank spot on the desk top select properties,in the display properties you will see settings.There is a option to adjust the screen size,move the bar to the left will increase the size.Under vVsta you will right click on a blank spot on your desktop select personalize,select display settings there you can adjust the bar to the left to adjust your display.Remember to apply the changes before you exit.
Good luck
Sep 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Screen moves
WinXP: Right click on blank desktop, click Properties, click Settings tab. Move the "Screen resolution" slide bar so that the whole screen is used up. In your case the vertical resolution is higher than the screens or horizontal resolution is not high enough.
Screens tends to do scaling. Check the "Native Resolution" of the screen and set it as the Screen Resolution.
Apr 16, 2009 | Acer Aspire 3000 Notebook
Panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Dec 29, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Windows XP not fitting full on 22 inch computer screen
Your new monitor will show a "native resolution". In the instructions below, try that setting first. If that fails try other settings.
- Right-click on an empty spot on your desktop
- Chose "Properties" on the menu that appears
- Click the "Settings" tab (at the top right)
- Move the "screen resolution" slider to a different number
- Click "apply"
- See how you like it
- Repeat until you get a setting you like.
Dec 27, 2008 | Computers & Internet
Showing small screen size in monitor
FROM THE DESKTOP ON YOUR COMPUTER RIGHTCLICK on your mouse you wil get dropdown menu select properties tab then you will get display properties menu select the settings tab and adjust the sliding control to increase screen resolution to fit your monitors screen if this doesnt work you may want to have a video graphics card installed in your computer.
Jan 16, 2008 | SAMTRON 55V 15" CRT Monitor
ASUS Eee 4G Notebook Logo
168 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
