Question about Canon PIXMA MP780 All-In-One InkJet Printer
My printer pixma mp450 do not start it say error 5100
It start pass a paper and then come an error number
  • 4,041 Answers
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 01, 2010
What is error message 5100 for this printer?
Code 5100 refers to a carriage that is not freely moving from side to side. Look to the far left and right for anything that would impede the carriage path.
Also, it is possible that the clear plastic encoder strip just behind the carriage path has become smudged with (most often) grease. You can clean the strip with a cotton swab dibbed in alcohol.
I hope this helps!
Mar 27, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error 5100, paper sticks, printer stops
Hi There
TrySolution 1:
Solution 2:
Hope it will hep
All Best:Pineworks
Jan 25, 2010 | Canon Pixma MP450 All-In-One InkJet...
My Pixma MP450 will not print, it just flashes "error code 5100"
Hello, DH.
First and foremost, disconnect the power cord from the back of the Canon Pixma Printers. This is an important step when working inside ANY electronic device.
A 5100 error is a carriage jam error. That means something is jammed in the printer at some location. The error can be caused by 4 different sensors.
The Timing Strip (or encoder strip, plastic strip about 1/4" in width) that passes through the back of the carriage assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use a flashlight to examine the strip. You really don't have much access to this strip unless you remove the cover, which can be difficult. But, clean with isopropyl alcohol and a Q-tip.
The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage arm, and the main logic card.
However, most of the time it is the timing strip which is easily contaminated with splattered ink.
If the problem persists, then use compressed air to blow the carriage assembly and the rollers.
Hope this helps.
Nov 07, 2009 | Canon Pixma MP450 All-In-One InkJet...
Error 5100 on MP450
It sounds like the fine cartridge movement is being restricted.
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Oct 18, 2009 | Canon Pixma MP450 All-In-One InkJet...
Have an MP460 and cleared a paper jam only to have the error code 5100 pop up and stop everything from printing
You will should be able to find information on that error for your printer by entering "error 5100" without quotes in the search box here. Then press Search. Then choose result 1 and follow the steps. Each step will have more detail available by click that steps link.
Hope this helps. Please remember to rate this information.
Thanks
Jun 04, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Error 5100
Have you taken the printer apart? as the issue I had with our spare printer was that the home mechanics around here had taken ours apart for some reason and had not put the paper roller pin back in correctly. it was sticking out preventing the ink tank holder from moving.
Dec 26, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP450
Try by holding the "triangle" button 5s, and release it.
Feb 16, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
