Question about Crosley Cr6001a Turntable
Crosley CR6001A: Left speaker barely audible
After a few days of use, the left speaker quit functioning. The sound from the left speaker is barely audible. This is quite frustrating because with stereo sound, this means that oftentimes I cannot hear one or more of the instruments in the song. If there are any simple solutions, I'd prefer to fix this myself. However if I'm unable to perform the maintenance myself I'll have to just take it in for repair or exchange
  • 3,289 Answers
Hi Eric,
I understand how frustrating this problem can be. The problem can be the result of several different things. Two of them are 1) blown speaker and, 2) blown left amplifier output.
Try listening with stereo headphones. If you can hear both channels clearly, the amplifier is most likely functioning correctly. This is desirable as amp repairs would probably be more costly than a driver (speaker) replacement. Make sure you vary the balance controls while checking for output on both L and R speakers. If the sound is intermittent, the volume or balance control may have dirt built up and may return to working properly by liberally spraying electrical contact cleaner around the stem (knob removed) with the unit unplugged. Use the extension tube to pinpoint the output along the stem. Be careful to keep from over-spraying as it may damage plastic and wood cabinetry. After spraying, rotate the knob fully back and forth several times and then plug back in and try for sound again.
If you can't restore the volume to the left speaker, you may have a blown speaker. This usually happens as a result of excessive volume which leads to distorted sound. If played this way long enough, damage to the speaker is unavoidable.
The speaker can not be fixed - but may be replaced. Replacing the speaker is something most people with conventional hand tools can do - with the unit unplugged. Finding the information on the speaker may prove to require some digging however. You'll need to know the size, wattage rating, impedance value in ohms, and frequency response. It would be best to obtain the exact replacement part if possible.
Other than this, you'll probably need to have it serviced professionally. Good luck!
Posted on Dec 07, 2012
  • Eric Landgrebe Dec 07, 2012
    Thank you very much for your detailed suggestions
    A few hours after posting my problem, I realized that I forgot to specify that when headphones are used, one of the ears are barely audible, similarly to the speaker itself. So it wouldn't be a problem with the speaker, probably some technical electronic problem.
    Currently, as I'm posting this comment, the sound is functioning fine. But at least half of the time, one side of the stereo sound is nearly inaudible, even with headphones
  • Steve Dec 08, 2012
    From your follow up info it sounds like an intermittant problem possibly caused by a thermal condition. As components heat up, they shut down . Once cooled enough, they come back by themselves. This should be repaired by an electronics shop without to much trouble. Good luck!
3 Suggested Answers
Grubhead
  • 5484 Answers
SOURCE: I have a Crosley 6005a. In turntable mode - sound
Check all conections to the turntable, also I think you should buy a new cartridge as a matter of course. I rather suspect it's (the cartridge) either **** or gone!
Posted on Jun 06, 2010
SOURCE: I have a Crosley CR66-PA. It's 120 volts and I
Same thing just happened to a friend of mine, he brought it to me. The transformer primary is Open Circuit, so hopefully that's all that has failed and it didn't do damage to the electronics. The problem I have now is finding out the ratings of the transformer so I can replace it with a 240V one (I'm in Austalia). The markings on the transformer don't come up with anything in google. Any idea what secondary voltage / VA rating it is?
Posted on Nov 17, 2012
No left a or b speakers
have you checked the speaker balance position as what you describe indicates you have the setting all the way to the right
Oct 03, 2016 | Audio Players & Recorders
Record continously skips after 4 or 5 seconds.
You need to apply more pressure to the stylus. This is done by adjusting a weight on the other end of the arm. See your manual for more details.
May 12, 2013 | Crosley Cr6001a Turntable
Barely audible sound out of left speaker
check audio balance option left and right speaker and set knob in middle position
May 31, 2012 | Panasonic SC-PM193 Micro SystemMicro Audio...
2006 pontiac g6 sound problems
That, my friend, is in your balance system of the radio itself. Check it with other speakers you know are good. You'll see what I mean.
Nov 28, 2017 | Cars & Trucks
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
No sound
Have you checked if this is only when you play CDs or also if you play Tapes or Radio? If sound is not present even if you use radio and tape, then the sound output IC is blown, and needs replacement. You need to see a professional technician for this. Also, see if your speakers are connected properly. Then try to connect another set of speakers (borow from a friend) and see if sound is audible. If yes, thn your speakers are faulty.
Aug 09, 2006 | Crosley CR79 CD Shelf System
Right Speaker Hit the Floor
Im sorry to say so, but the fact that speaker can still monitor volume has nothing to do with its disability to produce sound. Im not a speaker wiz, but I can think of two possible reasons for what happened: 1. something has broken inside the speaker. in this case you will have to get it fixed\replaced. 2. some disconnection accured from the hit, a wire got teared or loosed. in this case, you might get lucky. open the speaker, and search for any torn wires. if you are handy you may be able to weld, replace, etc.
Mar 24, 2006 | Altec Lansing VS2121 Computer Speakers
Crosley Cr6001a Turntable Logo
401 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
