Question about Boating
Hi i just bot a bass boat with a 40 hp mercury motor that has ben sitting up for 8 or ten years. so what should i do before i try to start it again because it wont start at all
The key start dosent start the motor and this is my first boat and im trying to fix it with the least amount of money spent
    Novelist:
  • 184 Answers
First know that they have a neutral safety switch which will stop the motor from spinning if the gear is engaged. so put it in neutral first.
Second- will it even go round? take the hood off and try to spin it by hand. Just to see if it is free. If it is stuck, check the lower unit oil for a lot of rust and water. That will stop it too.
Next - charge or change the battery,
Take the spark plugs out and see if there is any compression, or are there metal pieces found on the spark plug?
Then- or first- buy a book on your motor and a general book on boating.
Practice un-tying the boat and moving it off the trailer at home so you don't look like a novice at the ramp.
After 5 years the water pump should be serviced- use a garden hose and flush attachment or trash can full of water when running it at home- don't forget to put oil in the gas.
Posted on Dec 10, 2012
  • 3 Answers
SOURCE: I have a 90 Horse power Mercury outboard Boat
Sounds like the starter. Check if you have power at the solenoid from the battery with just the power on (key turned on, power switch on.) thats good-- you have power-- if not you have a wiring problem from your battery or main switch.
Otherwise you have a starter problem probably.
Posted on May 17, 2009
finish line
  • 207 Answers
SOURCE: 75 mercury boat motor not turning over
you have one of two problemsyour starter brushes are sticking or your solenoid is going bad next timme it happens take a hammer and lightly tap the starter if it turns over your starter is going bad if you try this repeatly and nothing then you have a bad solenoid they are not expensive if you do not want to tap the starter then just replace the solenoid the best way to find it is follow your main battery line to motor where it stops and breaks with two posts and then the hot goes to the sarter take a picture of it so if you need to take it with you u acn see where the wires go oriellys probally will have it is round and you battery will go to one post and the hot to the starter will go to the other there will be to little posts on it as well one to the key switch and the other is a groud
Posted on Jun 30, 2009
  • 75 Answers
SOURCE: I need a diagram for a carburetor for a 1990 Mercury Boat motor
this is just one of many carbs on a 50 hp merc
http://www.boats.net/parts/search/Merc2/Mercury/50%20(3%20CYL.)/9385911%20THRU%209469199/CARBURETOR%20ASSEMBLY/parts.html
if this isnt it just go to boats.net and check your modle number
good luck
Posted on Jul 06, 2009
Editor925
  • 285 Answers
SOURCE: 40 Hp Johnson outboard motors stalls out after a
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Posted on Sep 17, 2009
SOURCE: 20 hp evinrude boat motor will not start
broke key off of ignition trying to jump over, can't find wire to keep motor running, will start, but not stay running cause wired to toggle switch. can u help, please thanks, wayne (20hp johnson/evinrude
Posted on Nov 08, 2009
Gidday,i am trying to find out the year of my 50 h power mercury blue band . The serial number I have is 8016593 and I am looking for both the inner and outer wiring harnesses
50 hp is a 4 cylinder powerhead.. blue band denotes 80s model engines.. my dads was a red band 69 model.. the red band stopped in the late 70s like 79 .. the wire harnesses are almost identical from 40 hp on up to about 80 or higher, just a heavier set of starting cables.. may need to check into used equipment.. might find something easier there.. check mwith a mercury dealer near you also..
Nov 19, 2014 | Light Outboard Motor Boat Bass Fishing...
40 hp mercury starts hard
new points and plugs might help your problem
Oct 20, 2014 | Light Outboard Motor Boat Bass Fishing...
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
40 hp mercury
Hi Greg,
You Have A Short!
If You Put A New Fuze Does It Blow When You Turn The Key On, Or
As You Try To Start Or When You Operate The Trim Switch.
Try To Acertain What You Do When It Actually Blows The Fuze
Let Me Know
Cheers
Gordon
May 04, 2013 | Light Outboard Motor Boat Bass Fishing...
Hi i am looking for a repair manual, online, free would be best,for a 7.5 hp mercury outboard motor - no idea what year but must be early 90's at best. It won't start, fuel drips from under the head and...
Mel's Marine Service Inc. stocks those repair manuals and will ship them. I believe they run about $50.00. There phone number is 541-689-0136. They are open from 8-5 pacific time mon-fri and 9-2 on saturday.
Oct 08, 2009 | Light Outboard Motor Boat Bass Fishing...
Mercury outboard 60 motor turning over but not firing up.
get some starting fluid and spray a liberal amount into the air intake, then try to turn over. if it will not turn over with starting fluid you have a problem either with your ignition system, example: plugs, coils, wires, ect. If it does fire and then die out with a shot of starting fluid then you have a carb problem. If the boat has been sitting anything over a month thats where I'm betting the problem is. Post back after you find out if its a fuel, or fire issue and we'll start the repair process.
Jul 01, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
111 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
