Question about Maytag Neptune Washer
Maytag neptune smoking
I have a MAH3000 washing machine. a few months ago, it had smoke inside drum area when the cycles finished (per wife, i could never verify). it soon started sounding like a jet engine. last weekend i replaced the bearings and it is still smoking. it is doing a fine job cleaning the clothes and spinning the water out. last night after a complaint from the misses, i opened the door and there was a fine misty smoke. it smelled faintly of neoprene (best descpition i have) and damp. the smoke lingered a long time and did not smell or feel warm at all, it actually felt cool and damp. i hope you have heard similar and can help pinpoint the problem. damp, cool, lingering smoke inside the drum is confusing me?!?
    Genius:
  • 2,920 Answers
It could be the seal on the drum or it could be the belt getting too warm
Posted on Jan 12, 2009
  • jenerikj2001 Nov 09, 2010
    Did you ever find out what the problem was. Mine is doing the same thing! We just replaced the bearings last night and gave it a test run and it start smoking out of the hole where the water runs into the tub.
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Oct 01, 2012 | Washing Machines
My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its...
Hello, The earlier Maytag Neptune front loaders have a balance ring on the inner tub that has liquid in it and that causes the sloshing sound when you turn the tub by hand. That is normal.
I noticed that you have a MAH3000... Have you replaced your door latch wax motor yet? If not, it will fail and damage your control board located behind the timer. See NeptuneHelpSong for a video that explains the failure.
I hope this helps...
Apr 25, 2011 | Maytag Neptune Washer
Smok coming out of inside when we oped the door on
heater thermostat could be stuck on are the clothes warm after rinse?
Mar 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
The washine machine finished it's cycle but there was smoke coming out of the drum and a burning rubber smell
The usual cause of smoke coming out of drum is that the heater element has come on or stayed on with no water in the drum
Try it on a spin cycle only, if smoke still comes out of drum, then could be a faulty pump, or main motor is burning.
Jan 20, 2010 | Baumatic BTWM4 Front Load Washer
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
1,218 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
