Question about Razor MX500 Dirt Rocket
If you charge a mx500 while it is on will it ruin the bike
    New Friend:
  • 15 Answers
It is not designed to charge while the power switch is on..you will damage your bike and void your warranty.thats like putting the positive and negitve on backwards when u jump a car...don't do it, follow instructions...
Posted on Dec 30, 2012
How long can the Razor MX500 Dirt Rocket be ridden after charged?
Run time depends on a few things, including the weight of the rider, the terrain being riden over and the condition of the bike.
For example, a light rider riding on flat hard packed dirt or paved road with a bike that is in good mechanical condition - tires inflated to correct pressure, chain correctly adjusted/lubed, brakes adjusted, etc. - will have a longer run time than a heavier rider on soft undulating dirt with a bike that has not been maintained.
Generally you should be able get 40-45 minutes out of a new battery.
Check out the trouble shooting guide and user manual if you are getting less than half and hour.
http://www.razorama.com/ownersmanuals.html
Jul 31, 2013 | Razor MX500 Dirt Rocket
I just replaced the battery, but cannot get power. The "green" light on the charger stays on contstantly. what are the most likely reasons for this problem?
If you have replaced the 3 batteries inside and properly charged them overnight for 18 hours check to see if you have every connector plugged properly. IF you still have no power possibly the control modulator has failed. Is your throttle lighting up when you activate the switch? You can also check to see if the switch itself is working with a voltage meter. Leaving the bike outside in the rain can damage the MX500.
Oct 24, 2010 | Razor MX500 Dirt Rocket
Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
Apr 02, 2010 | Razor MX500 Dirt Rocket
The bike says that it is fully charged but is very slugish and will not go.
the battery is bad....because of over charge....u need a new one!....
Oct 06, 2009 | Razor MX500 Dirt Rocket
Charge port (blk. wire melted at the end) Smoke from motor
I'm sure it already is cooled down but it needs to cool down after an episode like that. Hopefully the motor stopped running as an over heating issue. If the charger wire melted on the motor where it plugs in, it was to HOT to plug it in at that moment, you should only charge a cool battery. Fuse you can check for look somewhere in the area of the battery, you might need to remove a cover or two to find, if there is one or maybe a fusible link is somewhere in the system.Without seeing this particular bike I cannot tell you exactly where to look. Maybe try online they have service centers for these bikes maybe in your area type in the info on the bikes info plate somewhere on the bike, as a random search for parts and info. Good luck!
How do you get the tire of the rear rim of the razor mx500 electric dirt bike???
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Jun 09, 2009 | Razor MX500 Dirt Rocket
Razor MX500 Dirt Rocket Logo
89 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
