Question about Qmadix Iharmonix Qi 7 Earphones W Mic QM QI 7 Headphones
I plugged my QI headphones into the computer and one of the buds seems to have stopped working. Is there any way i can fix them?
What is another way I can charge my phone? It stopped working w/a wall charger. Can you help fix the problem I have a Samsung Galaxy light LTE.
you can try Qi wireless charging. i have it on my samsung galaxy note 2, s3, s4, s5. just be sure your phone is compatible.
Qi Wireless Charging
Apr 12, 2016 | Samsung Cell Phones
My ear buds don't work. Is there a trick I don't know?
Did you check the volume control on our unit? Have you tried your buds elsewhere? Have you tried other headphones on your unit?
Sep 10, 2015 | Apple iPhone 5c
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
The left and right ear bud work some times. and if i turn the base were you plug it into the device it coukd work how can i fix it so they can both work at the same time.
Probably can't. What typically happens is that the base of the wire gets stressed from wrapping the cord around you media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more carefull with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Skull Candy LINK Earbuds Consumer...
My left headphone stopped working after a year or so. How can i fix this?
The copper wires inside the cable have broken. Since you don't know where the break occurred all you can do is to open the left headphone, remove the speaker, cut a piece of the cord and resolder it to the speaker. Test it, if it's fixed just put the headphone back together. If not, cut another piece. If you must cut more than a third of the cable to get it working then it's dead, just buy a new pair.
Jun 30, 2010 | Sony Bud Style Headphones
Right ear bud isn't working
i have this problem too, except it's the left side that doesn't work. i think that's because the copper wire inside broke or is severed partly. there is no way to fix it... just go buy a new one and this time try to kot coil the cords around hour mp3or ipod.
Oct 27, 2009 | Bose on-ear TriPort Headphones
Voice is Static on Receiving end
If you are using your speakers and not a headphone to hear the other person it will give you or them feedback.
I recommend that both parties use headphones and it will be more enjoyable and you wont have the feedback.
Hope this helps. Bud
Jan 28, 2009 | Logitech Quickcam Chat Webcam
Qmadix Iharmonix Qi 7 Earphones W Mic QM QI 7 Headphones Logo
24 people viewed this question
Top Qmadix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Qmadix Audio Player and Recorder Expert? Answer questions, earn points and help others
