Question about Acer Aspire One PC Notebook
Was reseting my pc to factory settings and my power cord got diconected. my pc shut down and now all i get on my screen is bootmgr is missing. it wont let me restart or any thing. dont know what to d
If i press ctrl alt del it takes me to set up screen but i dont know what to do from there.
  • kevin canada Dec 06, 2012
    did not need a disc and running windows 7
  • 57 Answers
You will need to reinstall the OS. You are getting the message because it didnt finish the factory settings completely
Posted on Dec 07, 2012
SOURCE: presario c751nr bootmgr missing
Have them load whatever OS you lost to them, if you have the OS cd, try installing it yourself.
Posted on Dec 14, 2008
  • 17 Answers
SOURCE: bootmgr is compressed
I know of three solutions, none of them will work without recovery or OS discs, and I can only guarantee one of them--the one that whipes your system. Try these in this order (assuming you have system discs);
#1 Boot from the system disc and choose the "repair" option. This is the quickest fix, and you lose anything.
#2 Boot from the system disc, and in your Start menu search type "Command Prompt". Open Command Prompt and type (hit enter after each line);
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
#3 Run a full system recovery from your system discs.
Now, if you don't have your system discs, and you're running Windows Vista, there is another possible option. If your computer is fairly new then you probably have a WinRE partition for recovery, (a "factory image" drive)? I won't go into this now, if you have your discs option 1 or 2 should work for you.
Posted on Feb 27, 2009
fraywing
  • 37 Answers
SOURCE: cannot restart laptop
"Boot with the Vista DVD, when it enters Setup hit your SHIFT-F10 keys Setup will run "cmd", and drops you to a command prompt that is running with SYSTEM privileges.
Then at the command prompt type the following (hitting <enter>) after each line.:
del bootmgr
ren temp bootmgr
hope this helps! :)
cite: http://www.cybertechhelp.com/forums/showthread.php?t=151686
Posted on May 30, 2009
sidlas
  • 95 Answers
SOURCE: my laptop says BOOTMGR is missing what does that means?
tap f8 when boot,in menu go to last good known configuration>enter,post reply if not helps will give further instructions if needed.
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: laptop help
sounds like something got hosed up......use the recovery partition and reload windows....easiest thing to do....Good luck...
Posted on Jan 15, 2010
Itoshiba satellite bootmgr compressed how to fix t
When first turning it on press ESC or F10. This should take you to the BIOS screen. In this screen you can choose to reset the OS to factory settings. It is possible you have a rootkit virus or similar malicious bug. If so, a certified tech may need to address
the issue.
Apr 10, 2014 | Toshiba Satellite A205-S4617 Notebook
Windows cant open bootmgr is missing, press ctrl+alt+del but not working how to fix it aspire one D257
Have you tried a System Restore/Recovery? Can you boot to safe mode? Try the restore/Recovery procedure: Shut down, unplug, remove battery, plug in, push the on button and When Acer splash is on screen hold Alt and keep pressing F10...
Apr 14, 2013 | Acer Aspire One D257 Netbook
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Feb 20, 2013 | Acer TravelMate 2300 Notebook
Sony f series missing BOOTMGR
Bootmgr is missing - Vista, Windows 7
Go to this WEB site for instructions to fix this problem
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
Jul 21, 2012 | Acer Aspire Computers & Internet
Bootmrg is missing acer travelmate 2480
  • HI. Welcome to Fixya.
  • Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.Detach any external hardware such as an external hard drive or printerPress the Power button to boot your Acer laptop. Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.Click "OK" in the notice window to proceed with resetting your Acer laptop.Wait while your Acer laptop is reset to factory settings.
    Hope this resolved your issue.
    Thanks for contacting Fixya. Bye for now
  • Jul 17, 2011 | Acer Computers & Internet
    My laptop says that the btmgr is missing when i start it. an error occoured during a reset of factory settings. im prompted to ctrl + alt + del to restert. it works but goes back to the btmgr missing page....
    OOT TO SAFE MODE, SYART > RUN > TYPE > CMD > HIT ENTER
    TYPE, (IN NEW WINDOW) FIX
    OR
    If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
    attrib -c c:\bootmgr
    attrib -c c:\ntldr
    OR
    GET TO COMMAND PROMPT AND TYPE
    compact /U C:\bootmgr
    compact /U C:\ntldr
    (bOOTMGR REPLACED NTLDR IN NEWER SYSTEMS
    or if you can get to command prompt type fix bootmgr
    and fixmbr
    Dec 11, 2010 | Computers & Internet
    Bootmgr is missing
    try check the hard drive and make sure the power cord is connected properly the same thing happened to me Bootmgr missing and I tried to put the install disk in there but it still kept saying the same thing not knowing it was the power connector to the hard drive...
    Sep 01, 2009 | E-Machines eMachines Desktop PC
    The power shut off while i was factory resetting it and now it keeps saying BOOTMGR is missing
    This usually happens after a bad shutdown.
    To solve, insert the Restore DVD, and follow the prompts, until you get to the point where the system ask if you want to fix the Boot file.
    Once the process is completed, you'll be up and running again.
    Please don't forget to rate this answer if it helps
    Jul 23, 2009 | Toshiba Satellite M305-S4826 Laptop
    A few days ago i had the problem were my laptop was sayin bootmgr missing i have since been able to reinstall my laptop and am back on to the desktop page with everything wiped, but now it keeps freezing...
    When you re-installed the OS, etc. The power saving features in the OS (XP?) went back to their factory values. Meaning that now after so many minutes the machine is standing by or hibernating...
    Right clock on the desktop and then click on properties. Click on the Screen Saver tab and then click on the "Power..." button.
    Set the power options properties to something you like...
    Mar 09, 2009 | Computers & Internet
    Acer Aspire One  PC Notebook Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
