Question about Volkswagen Vehicle Parts & Accessories
Key codes for golf 2008 tdi - Volkswagen Vehicle Parts & Accessories
  • Volkswagen Master
  • 694 Answers
Contact Volkswagen service
Posted on Mar 02, 2014
I have a fault 296 on my golf tdi 2008 can you please tell me a little about the fault please.
296 is not a valid code, I will assume it is a P0296, if that is not the case let me know.
Code P0296 is triggered when the Power Train Control Module (PCM) detects that the acceleration rate of the crankshaft for Cylinder #12 was less than a calibrated amount. During normal conditions the PCM turns the Fuel Injectors ON and OFF in the Fuel Injection System. SymptomsPossible sumptoms of OBD code P0296
- Engine Light ON (or Service Engine Soon Warning Light) - Engine Misfire - Engine Run Rough - Low MPG CausesPossible causes of OBD code P0296
- Fuel Injector #12 - Faulty or Corroded Fuel Injector #12 Connector - Plugged #12 Fuel Injector - Dirty #12 Fuel Injector Possible Solutions- Clean Fuel Injector #12 Connector - Clean Fuel Injector #12 - Replaced Fuel Injector
Feb 02, 2012 | 2008 Volkswagen Golf 1.6
The keyless remote for my 2000 Golf TDI was working only once in a while so I put new batteries in and now it doesn't work. Is there something I can do to make it work again?
Check your driver's manual, there should be a sequence to re-code the fob for your ignition. Something like hold unlock for 30 seconds, turn key to on position 5 times, or some such.
Jan 13, 2011 | 2000 Volkswagen Golf
2002 VW Golf TDI open door light & alarm
check door switches remove 1 at a time and unplug it once you find the bad switch lights will go out
un plug 1 at a time
Jan 22, 2010 | 2002 Volkswagen GTI
How do I fill the gearbox oil on my Seat Leon 1.9 TDi? (same engine as a VW Golf 1.9 TDi)
If the car is a manual shift,the filler / level plug (Allen key) is on the front of the gearbox. Simply remove and fill to this level. Box holds 2.5 litres of 75/ 80 grade oil. Do NOT use EP grade
All the best
John
Aug 27, 2009 | 2005 Volkswagen Golf
Reduced power when driving Mk4 Golf TDI
common faults for your symptoms are n75 valve open or short circuit or vains sticking in turbo giving an overboost fault,get the code and i will tell you whats causing it
Feb 19, 2009 | 1997 Volkswagen Golf
05 Golf 1.9D TDI engine code; BKC
i have problem vith car,my car is golf v 1.9 tdi motor code is BKC...number of code for problem is P0642 ("Sensor Reference Voltage "A" Circuit Low")
Jul 09, 2008 | 2005 Volkswagen Golf
VW Golf GT GTi 2L start problem
worn coil pack?
its a problem with some golfs
type worn coil pack golf tdi on google and you should see everything on it. i think theres an uprated set out now don't quote me on it tho!
Jul 05, 2008 | 2004 Volkswagen Golf
Golf mk5 tdi sometimes wont start.
You didn't say how you got round this problem when it happened - did you keep on trying or go away and come back later? I'm thinking you may have an immobiliser issue with the ignition key not being read correctly by the detector coil in the steering column. Did you use the same key on both occasions, and did you open the car remotely or manually?
Jun 28, 2008 | 2004 Volkswagen Golf
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Volkswagen Vehicle Parts & Accessories Experts
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Bruce S
Are you a Volkswagen Vehicle Part and Accessory Expert? Answer questions, earn points and help others
