Question about HEWLETT-PACKARD HP ProBook 6550b Notebook
Laptop does not turn on after bios update - HEWLETT-PACKARD HP ProBook 6550b Notebook
    President:
  • 949 Answers
Try setting the BIOS to default, then rest the settings.
You can try to re-flash the BIOS version just before the latest version.
The Wz number you posted does not match a 655.
Read the manual carefully about how to flash the BIOS.
Look in manual for clearing CMOS, if you have it, clear CMOS, set BIOS to default, and reset, if this does not work, re-flash the next to oldest BIOS version, if you have (example) F23, then flash to F22.
Posted on Dec 06, 2012
Toshiba c660 laptop reflash bios via usb
If the laptop does not turn on, then it is impossible to run the BIOS update.
Mar 04, 2014 | Computers & Internet
Hang update bios
You have to remove the bios chip from the mainboard and flash it with the right bios version out side the laptop.
Feb 08, 2014 | Computers & Internet
After bios update no display on toshiba L455D-S5976
It sounds like you updated with the wrong BIOS or a BIOS version that isn't designed for your specific model laptop. You will have to revert back to your old BIOS version.
Dec 29, 2012 | Toshiba Satellite L455D-S5976 Notebook
I have acer aspire 5500z notebook it has been shuted down during the bios update i want to repair the bios because whenever i turn it on it gave nothing but black screen any idea
Before I explain about the troubleshooting steps to resolve this issue, let me first give you a brief information about the BIOS Updates.
The BIOS Updates or any Firmware Updates are those Updates which will be installed in the Hardware chipsets.
For, example the BIOS Update will be installed in the BIOS Chipset.
It is required to extreme precaution which installing such Firmware Updates.
It is required to keep the Computer ON while performing these Updates.
If these Updates are not installed successfully or if the Computer is turned OFF during the Installation procedure, this might lead to a Hardware failure.
Hence, for such issues it would be better to get the Unit examined at the Authorized Service Center.
In this case, as the Computer was turned OFF while installing the BIOS Update, the issue might be with the BIOS Chipset.
It is required to get the Unit serviced at the Service Center.
The BIOS Chipset will be flashed to resolve this issue.
This will be done by the trained Technicians at the Service Center.
Hope this helps.
Please feel free to ask further questions.
Aug 15, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hello. five minuets a go.. i go to update my BIOS.. and my Notebook willl rebot until the BIOS update is finished.. then.. my Notebook not Turn ON again.. Please Reply me ASAP. Thank's
If you fail to update the bios, you may be left with a broken, unrepairable worthless laptop.
There are a few guides available on google, depending on your laptop make.
look here at the first result in the list. You may just be in luck :)
http://www.google.co.uk/search?hl=en&q=failed+laptop+bios+update&meta=
Aug 06, 2010 | Acer Computers & Internet
Bios update 3000 c200
Hi deartone, you can try these steps:
You can power drain the pc if the bios won't update.. Turn off the pc
then unplug cables from the desktop or laptop then remove the battery (only on laptop) , then press and hold the power button for 5 seconds.
Then replug all cables and batteries. Then turn on the pc and check the Bios if it updates.
You can call our technical support if it isn't work at 1-877-4-536686.
we are open 24/7...
Apr 14, 2010 | Lenovo 3000 C200 Notebook
Hi, i was carrying out a bios update on my toshiba equium A60 laptop. it dicided to freeze on me, i tried to turn the power off this didnt work i ended up removing the battery. when the battery was...
That does not sound good. If the Bios update was incompleted and the BIOS ROM was erased then the computer might be dead. You would need to take it to someone who can pull the bios chip and re-burn it using a device or burn the bios to a new chip and then install it. Whenever you are updating your bios you are taking a risk and that is why they tell you to only update when you are having computer problems. And never update a Laptop on battery powern alone. I am not saying that you did I am just giving advice.
Oct 18, 2009 | Toshiba Satellite A60 Notebook
LAPTOP NOT WORK AFTER HAD UBDATE BIOS (UBDATE DIDN'T FINISH)
Having a Bios update fail is not a good thing. Typically, it renders your laptop motherboard useless as the bios is embedded on a chip. Try this:
Use FN+B while powering on. Hopefully it will enter BIOS recovery mode. From there you can try to flash either the same or older version of the bios. You will likely need a floppy drive too.
May 19, 2009 | Computers & Internet
HEWLETT-PACKARD HP ProBook 6550b Notebook Logo
198 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
