Question about Garmin GPSMAP 60CSx GPS Receiver
I have cganged settings on my GPSmap 60CS and it now display only waypoints and not complete tracks. Can anybody out there advise?
    Problem Solver:
  • 15 Answers
On the Map page press Menu. From the options shown choose Setup Map. Go to Track tab and make sure Saved Traks is not set to OFF.
Posted on Mar 09, 2009
Chat session ended by mistake. I need help with getting my Garmin GPSMAP 60 CX up and running. 1. I have successfully loaded Trip and Waypoint Manager on the computer 2. I have the unit hooked up to the...
You cannot load maps to the unit using the Trip and Waypoint Manager software. That software only does what it's called - it transfers routes and waypoints. To install maps onto your GPS, you will need Mapsource, which normally comes with the maps. Once it's installed on your PC, you hook up your GPS with a mini-USB cable, choose which maps you want transferred to the unit, and then the Mapsource software will knit the map segments together and transfer them over to the unit. Hope this helps.
Jan 06, 2011 | Garmin GPSMAP 60CS GPS Receiver
How do I clear the Waypoint Memory of my garmin 60 ?
Hello
Follow the instructions shows in picture below
cmptrlink_14.jpg You can get more help from the manual by downloading it Click here to download
Hope this helps, if so do rate the solution Good Luck
How do i erase tracks on 525S
To edit an existing waypoint:Or MOB
1. From the Home screen, select Information > User Data > Waypoints.
2. Select the waypoint you want to edit.
3. Select Edit Waypoint.
4. Select the waypoint attribute you want to change (Name, Symbol, Depth, Water Temp,
Comment, or Position).
To delete a waypoint or an MOB:
1. From the Navigation chart, use the map pointer ( ) to highlight the waypoint or the MOB
on the Navigation chart.
OR
2. Select the waypoint or the MOB you want to delete.
3. Select Review > Delete (The Review button is only shown when more than one waypoint
is in the vicinity.)
Sep 24, 2009 | Garmin Gpsmap 525s Dual Frequency Combo...
Tracking storage options GPSMAP 295
Every waypoint in the track has date/time, altitude and position. Second and subsequent waypoints will enable calculation and display of leg length, time, speed and direction between each par of points. The track can be displayed in 3D; in Google Earth for example. As far as I know there is no way to change the interval.
Jul 13, 2009 | Garmin GPSMAP 295 GPS Receiver
Garmin GPSMAP 60CS displays wrong date
mou exoun dvsei ena gps to opoio mesa einai ola sbismena.
prospathw na tou perasw ena ellhniko xarth alla den mporw...
xreiazomai help.......
Feb 03, 2009 | Garmin GPSMAP 60CS GPS Receiver
Unable to load coordinates for a projected waypoint
There are two ways you can load a way point.
1. Hit mark on your GPS. Push up on your rocker until the coordinates are highlighted. Once they are hit enter. From here you can change the coordinates to what ever you want.
2. If you have the software (Mapsource Trip & Waypoint Manager) you can enter the waypoint by going to "Edit" then "New Waypoint" or hit Ctrl + W as a shortcut. Once you create all the points you need, plug in your GPS and turn it on, then click "Send to Device"
Make sure that your mapsource and GPS are both setup on the same datum and lat/lon style corrdinates as well or it could throw it off.
Jan 20, 2009 | Garmin GPSMAP 60CS GPS Receiver
Inaccurate Garmin GPS
Have you enabled the 'WAAS' option?
This improves accuracy greatly
Jan 19, 2009 | Garmin GPSMAP 295 GPS Receiver
GPSMAP 60CSx
You can't turn the navigation back on with this method. You must once again highlight the waypoint you want to navigate to in your Fine>Waypoints screen and then press the "Go to" highlighted button on the screen.
Jun 25, 2008 | Garmin GPSMAP 60CS GPS Receiver
60CSX altimeter problem
What do you think it should go to?
May 03, 2008 | Garmin GPSMAP 60CS GPS Receiver
Trouble connecting to any computer
Hmmm..
Make sure your using a USB cable, specifically a USB cable with a mini connector on the end. Specifically, a USB cable with the second one from the left in this picture:
http://en.wikipedia.org/wiki/Image:USB_types_2.jpg
If you are using the USB port, you should have no need for setting COM ports.
Another technique you can use (which I just figured out today) was to place the Garmin Unit in "USB Mass Storage Mode". This allows you to offload saved tracks, but I don't think you can download waypoints or other things that the WayPoint Manager allows.
You can access this option via the Garmin Unit
Goto: "Main Menu" -> "Setup" -> "Interface". Press Down to get to the button "USB Mass Storage". Plug in that USB Mini cord, and you have a thumb drive!
Good Luck!
Oct 14, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin GPSMAP 60CSx GPS Receiver Logo
197 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
