E47 and no spin cycle on ATF8000fs1
Our ATF8000fs1 wash machine stopped doing the spin cycle. The drum still turns slowly during the wash/rinse cycle, but it won't do the high speed spin. I tried a spin cycle only with no clothes in it and had the same issue. I saw where to hold down Start/Pause and Cancel and that gave me "E47" code. Any ideas?
  • 1 more comment
  • David Marshall Dec 06, 2012
    I should have said: this is a Frigidaire Affinity
  • David Marshall Dec 07, 2012
    Richard Roth's answer is right on the money. I found the part locally for $84 and installed it last night. Then sat and watched for 10 agonizing minutes as it when through it's slow spins in spin cycle. The last 2 minutes of the spin cycle it kicked into high gear and we were off and running. Thanks!
  • Richard Roth
    Richard Roth Dec 07, 2012
    I'm glad you are up and running! Have a great Holiday season!
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
E47 error is for the door lock assembly. Here is the part to order.
Here is a video to show you how to make the repair.
Posted on Dec 07, 2012
Testimonial: "This was the exact problem and solution - thanks!"
  • Richard Roth
    I am glad I was able to help you. Thanks for using FixYa!
SOURCE: Kenmore 44092500 Won't complete spin cycle
need a door latch assembly
Posted on Aug 30, 2008
SOURCE: high speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Posted on Mar 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Roper washer ras7133kq1will not spin enough to wring out clothes
bad motor most likely. easy fix
Posted on Feb 05, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
sonicboomele
  • 1557 Answers
SOURCE: Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Posted on Apr 28, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
I have a LG WM0642HW washing machine. During the wash and rinse cycles the machine runs really rough and will not turn the drum over. Sometimes the machine will stop and go into the LE error. I have...
Your problem requires very skilled LG technician to check the wiring circuit from the control board to the motor and hall sensor. Very possible that the control board is bad but highly unlikely. Suspect the wiring harness with high resistance to the motor.
Good luck
Jun 16, 2011 | Washing Machines
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
High speed drum rinse ..drum not spinning during rinse cycle
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
229 people viewed this question
Top Washing Machines Experts
