Question about Fisher Paykel EcoSmart GWL15
Power button on GWL15 has issues
Its become difficult to push the power button ... you have to press and press and press and eventually the washer turns on. All other buttons work, this one seems to have a connection problem. Suggestions for getting it fixed/replaced?
  • Fisher Expert
  • 554 Answers
You will need to get a new tac switch installed into the display board
and put some clear packing tape over the crack on the decal to stop water getting in again and wetting the new switch.
Posted on Dec 15, 2013
PTT button on RDV 2020 is hard to push
This problem is typically caused by small component behind the PTT button being cracked or broken. The RDX series radios respond best if the user presses the PTT button in the center versus the top or bottom sections of the button. Once the button becomes hard to press it is best to get the radio repaired. Commonly if the radio remains in use the PTT issue will get worse as the internal PTT component is pressed harder, pushing it further away from the outside button and eventually loosening it from the component board.
Best regards.
Apr 18, 2014 | Motorola RDV2020 Two Way Radio2 VHF 5...
LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
Jan 31, 2010 | LG WM2455 Front Load Washer
No power press power button blinking red battery light
If it is not taking a charge your power adapter is loose. To confirm this press on the cord where it plugs into your laptop and continuously press the power button if it powers up thats your problem. You may need to press the cord at various angles before you get it to power up push it in and pull to the left, then the right, up, down and so forth.
If this is your issue you can temparly fix it by using duct tape once you find the right position for the cord that will work for awhile but you will need to get it soldered eventually. If you know someone who knows how to solder ask them if they will do it for if not the repair will be approx. $100
Dec 16, 2009 | Gateway M685-E Notebook
Fisher and Paykel EcoSmart GWL15 Machine won't agitate or spin - two yellow lights come on, and machine beeps every second or so. This happens even with the power off.
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 12, 2009 | Fisher Paykel EcoSmart GWL15
No power washer will not work
Sounds like a control board failure, sparks are never a good thing. Better to get a serviceman look at it unless you are an electrician and can do an insulation test after working on it.
Feb 03, 2009 | Fisher Paykel EcoSmart GWL15
Fisher&Paukel washer
might have something stuck in drainage area. see my post on "eco smart won't drain, smells hot" on how to remove motor on bottom of washer.
might also try another website, www.ths.gardenweb.com/forum/laundry to see if anyone on there has an answer.
Oct 13, 2008 | Fisher Paykel EcoSmart GWL15
Power wont go on fisher paykel eco smart GW11
first step is to make sure you do have power to your washing machine.
if you press your power button and you dont get any response,you will find the your electronic have gone.
Its called a power module.
They do have fuses in them.
Jul 31, 2008 | Fisher Paykel EcoSmart GWL15
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Defective power button?
Is there power in your wall outlet, try something else there. Next try the fuse in your washer plug, may have blown.
Dont forget to rate.......
Nov 12, 2007 | Fisher Paykel EcoSmart GWL15
Power button
This also helped me. Thanks
Oct 26, 2007 | Whirlpool LHW0050PQ Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
