Question about Apple iPhone Smartphone
How do i get out of speaker mode - Apple iPhone Smartphone
    Problem Solver:
  • 17 Answers
Is this when you're on a phone call? If so, all you need to do is have a look at the screen when you're on a call and tap on the speaker icon option from the 6 options provided. It'll be the top right option. Hope this helps :)
Posted on Dec 16, 2012
Speakers stuck in diagnostic mode, know how to get them out of it?
The user manual states to plug the sound cables into the correct sound output jacks of the sound card of your computer to get the speakers to come out of diagnostic mode. I am guessing that once a signal is picked up on the audio cables that the speaker will switch modes.
Jun 12, 2014 | Harman Kardon HK695 Computer Speakers
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
In radio mode, all speakers do not work
Radio will default to 2 channel stereo. You will need to use one of the soundfield processing modes to expand. Try using surround mode button to get to 6 channel or pro-logic.
Dec 29, 2009 | Sony STR-DE597 Receiver
People can hear me but i cant hear them
To confirm that ur speaker is dead try to speak in the loud speaker mode. If u happen to hear them in loud speaker mode but not in the normal speaker mode then its confirmed that u need to replace ur speaker unit.
Thankyou
Jul 31, 2009 | RIM BlackBerry Curve 8310 Smartphone
One speaker only works in Mono mode
I would be checking the set up mode , you might have it set to left or right channel only , but in mono mode both speakers will come on through one channel
May 25, 2009 | Onkyo TX-SR875 Receiver
Speakers
Test the speakers by changing source to the disc mode, and inserting a dvd into the HTS. If you get sound on all 5 speakers in DVD mode, then your speakers are still good. If you don't get sound on all 5 speakers, then press the "SURR" button to try the sound in stero, dolby, or other modes - one of these should give you sound on all 5 speakers. If you still don't get sound on all 5 speakers in dvd mode, then there is a problem with the speakers or speaker wires.
If you do get sound on all 5 speakers in disc (dvd) mode, but not when in TV mode, then take out the red and white AV cable, go buy a digital audio or SPDIF cable, and plug in the digital audio or SPDIF cable from the digital audio OUT of your TV or cable/satellite box to the "DIGITAL IN" of the HTS.
-Tha Mp3 Doctor
Feb 17, 2008 | Philips HTS3440/37 System
RCA HOME THEATER SYSTEM REAR SPEAKERS NOT WORKING
cheak the mode u are in theter mode reg sterio mode wont do the back ok cheak settings dsp modes
Jan 20, 2008 | Audio Players & Recorders
No sound in surround modes
I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any surround mode from any source.
Aug 15, 2007 | Onkyo TX-SV525 Receiver
Apple iPhone Smartphone Logo
20 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
