Is it possible to connect MS Outlook to yahoo.com?
    Problem Solver:
  • 5 Answers
Yes it is using a program called ypops. You can download and install ypops free from the ypops website. Once ypops is installed you can then to to outlook and add a new account for your yahoo email address enter youremailaddress@yahoo.com and for the incoming mail sever enter 127.0.0.1 for the outgoing mail server also enter 127.0.0.1 the outgoing server requires authentication. Also increase the server timeout to long 10 minutes.
Posted on May 10, 2009
  • 99 Answers
If you don't have a premium Yahoo mail account, the short answer is no. However, there is a work around using a program called YPOPs. More information is here. Please let me know if this was helpful.
Posted on Mar 21, 2009
  • 32 Answers
Yahoo's UK page has instructions on this and here they are: id rather paste theirs than type my own...
  1. From the Tools menu, choose "Accounts."
  2. Select the "Mail" tab.
  3. Click the "Add" button.
  4. From the Add menu, click "Mail."
  5. In the text box labelled Display Name, type your name and click "Next."
  6. In the Email Address box, type your Yahoo! Mail address (be sure to include "@yahoo.com") and click "Next."
  7. Under "My incoming mail server is a…" select "POP3."
  8. Type "pop.mail.yahoo.co.uk" in the Incoming Mail (POP3, IMAP, or HTTP) Server box.
  9. Type "smtp.mail.yahoo.co.uk" in the Outgoing Mail (SMTP) Server box.
  10. Click "Next."
  11. In the Account Name box, type your Yahoo! Mail ID (your email address without the "@yahoo.com").
  12. In the Password box, type your Yahoo! Mail password.
  13. If you want Outlook Express to remember your password, check the "Remember password" box.
  14. Do not check the boxes labelled "Log on using Secure…"
  15. Click "Next."
  16. Click "Finish."
Important: The Yahoo! Mail SMTP server now requires authentication. To turn this setting on:
  3. Double-click the account labelled "pop.mail.yahoo.co.uk."
  4. Select the "Servers" tab.
  5. Check the box next to "My Server Requires Authentication."
  6. Click "OK."
To control deletion of messages from the Yahoo! Mail server:
  4. Select the "Advanced" tab.
  5. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook Express, don't check the box.
If you're unable to send email, try using port 587 when sending via Yahoo!'s SMTP server. Here's how to make this change:
  1. From the "Tools" menu, select "Accounts."
  2. Select your Yahoo! POP account and click the "Properties" button.
  3. Click the "Advanced" tab.
  4. Next to "Outgoing server (SMTP"), change port 25 to 587.
  5. Click "Apply." Then click "OK" and "Close."
Posted on Jan 12, 2009
  • Tom Zorn
    Tom Zorn Jan 12, 2009
    im sorry. i should have read these. its basically the same but here use these instructions instead!
    5. In the text box labeled Display Name, type your name and click "Next."
    8. Type "plus.pop.mail.yahoo.com" in the Incoming Mail (POP3, IMAP, or HTTP) Server box.
    9. Type "plus.smtp.mail.yahoo.com" in the Outgoing Mail (SMTP) Server box.
    10. Click "Next."
    14. Do not check the boxes labeled "Log on using Secure…"
    15. Click "Next."
    16. Click "Finish."
    17. Select 'plus.pop.mail.yahoo.com' under 'Account,' and click 'Properties.'
    18. Click the “Servers” tab.
    19. Under “Outgoing Mail Server” check the box next to “My server requires authentication”
    20. Click the 'Advanced' tab.
    21. Under “Outgoing mail Server (SMTP)”, check the box next to “This
      server requires a secure connection (SSL). Enter port number “465” in
      the “Outgoing mail (SMTP)” field.
    22. Under “Incoming mail (POP3)”, check the box next to “This server
      requires a secure connection (SSL)". The port number in the “Incoming
      mail (POP3)" field should automatically change from 110 to 995. If it
      doesn’t, make sure the port number is set to 995.
    Troubleshooting instructions.
    If you followed the above configuration steps, you should be all
    set. However, if you cannot send or receive mail with your email
    client, try the following tips.
    The Yahoo! Mail SMTP server requires authentication. Make sure you have enabled SMTP authentication. To turn this setting on:
    3. Double-click the account labeled "plus.pop.mail.yahoo.com."
    6. Click "OK."
    To control deletion of messages from the Yahoo! Mail Server:
    5. In the Delivery section at the bottom of the window, check "Leave a
      copy of messages on server" if you want to save your Yahoo! Mail
      messages on the Yahoo! Mail server as well as on your local computer.
      Do not check this box if you want your messages to be deleted from the
      Yahoo! Mail server once you have received them in Outlook Express.
    We strongly recommend that you enable SSL for both POP and SMTP, as
    detailed in the above instructions. This will ensure that your Yahoo!
    ID, password and email messages are transmitted securely between your
    mail client and the Yahoo! servers. However, if you choose to not use
    SSL for SMTP, your email client will likely default the SMTP port to
    25. If your ISP blocks port 25 or if you're unable to send email, then
    you will need to use port 587 when sending via Yahoo!'s SMTP server. To
    make this change, please follow the directions below:
    1. From the "Tools" menu, select "Accounts"
    2. Select your Yahoo! POP account and click on the "Properties" button
    3. Click on the "Advanced" tab
    4. Next to "Outgoing server (SMTP), change port 25 to 587
    5. Click "Apply", then click "OK" and "Close"
  • Tom Zorn
    Tom Zorn Jan 22, 2009
    did you try this? let me know how its working
How do I fix microsoft outlook 2007 .pst file corruption?
The Microsoft repair tool is the only one that works - and you have to create a new PST file, and recover items from the old one. Some items will be recovered - but I never get close to 100%....
If it didn't help try to use Recovery Toolbox for Outlook designed for Microsoft Outlook database repair if PST file damaged. Outlook fix tool can solve the problem of corrupted Outlook databases and fix errors. For more: The one tool that knows how to fix Outlook 2003 corrupted files in fast...
Oct 24, 2015 | Microsoft Computers & Internet
E-mail on 530 dell yahoo. com mail
Need more details for the same...
Are you using MS Outlook or Outlook Express Or Windows Mail or logging on to the Mail server??
For Outlook / Windows Mail issues you can delete and recreate the account to rectify the error (Your saved mails won't be deleted).
Please give more details to help you further.
Nov 11, 2009 | Computers & Internet
'Your e-mail server rejected your login. Error 0x800CCC92.
try log in ur yahoo account directly and chk if the user name and password is fine
Apr 16, 2009 | Computers & Internet
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
Hi this is varma i want ms outlook how can i install in my pc
only possible way u buy ms office small bussiness or other where it is included
If helped rate fixya
also can download it via torrent but its illegal
Jan 12, 2009 | Computers & Internet
I got a new computer and need to set up my e-mail accout
If gonna use MS outlook just open the it. If it is the firt time the MS outlook is going to be opened then it will display internet connection wizard and ask you for a display name just follow the instructions.if the outlook as been used, Ok just follow this steps. Go to tools, accounts and add the internet connection wizard appears and just follow the instructions. Cheers.
Nov 30, 2008 | Computers & Internet
Email box becomes full. I want mail once opened removed from my box and stored on my computer so that I don't get messages saying your box is nearly full.
   For this you have to use OUTLOOK EXPRESS where you can also increase the space for outlook according to your requirment,But not possible with the wemail based services like hotmail, Yahoo, etc.And as far as concern of space YAHOO providing unlimited space which have no bounds.Therefor,You can switch over to yahoo for unlimited space.
Thanks for using fixya.
Nov 26, 2008 | Computers & Internet
My partner deleted the microsoft program from the computer. I have re installed it, but cannot access any of my emails when I sign in ( PurpleJan@live.com.au )I can see I have emails but cannot open the...
My best guess as to what your problem is, is that you need to tell Outlook what your mail servers are......... And as each Internet Service Provider has their own your best bet is to give your ISP a call and ask the what your pop3 and smtp servers are.
Then you need to tell outlook what those servers are, the procedure for that varies a bit depending on what version of MS Office/ Outlook/ Outlook express you have.
A possible way for you to contact Live would be to sign up for a free web based email such as MSN, Yahoo, Hotmail, or gmail. As these email servers are all web based and don't rely on Outlook for you to receive a message they should give you a reliable way for Live support to contact you, and a backup email account for the future ;)
Hope this helps
Dave
Nov 06, 2008 | Computers & Internet
I want to yahoo mail inthe outlook express?
You can add additional (POP) accounts in Outlook 2003. Or if you still prefer OE (from help.yahoo.com):
Here's how to "POP" mail from Yahoo! Mail Plus into your Outlook Express:
  10. Click "Next."
  15. Click "Next."
  16. Click "Finish."
  21. Under “Outgoing mail Server (SMTP)”, check the box next to “This server requires a secure connection (SSL). Enter port number “465” in the “Outgoing mail (SMTP)” field.
  22. Under “Incoming mail (POP3)”, check the box next to “This server requires a secure connection (SSL)". The port number in the “Incoming mail (POP3)" field should automatically change from 110 to 995. If it doesn’t, make sure the port number is set to 995.
Computers & Internet Logo
569 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
