Question about One Step Ahead New Holland Tractor Set
New holland TL 100 tractor will not start after shutting down while running
Was low on fuel but filled it up and primed it,
2014 New Holland T495. 10 below zero today & tractor starts fine, then shuts itself off. When I restart, why doesn't it move & then shuts down again?
10 below is very cold so there may be sensors in the tractor that is preventing damage from icing
could be the fuel is freezing, coolant frozen, oil to thick to lubricate properly
Jan 09, 2016 | Garden
Why won't it start?
Hi Brian:
1) Spark - pull the plug, connect the lead, hold against the head, spin it over. should be a hot blue spark.
2) Fuel - I'd be suspicious of your fuel. Here's a trick I use ALL THE TIME on my Craftsman ride on. For cold starts I remove the air filter and prime the carb with a squirt of fuel. It starts and keeps running. Without the prime it is a PITA.
Hope this helps.
Oct 19, 2015 | Garden
What causes a Poulon Pro riding mower with a 19.5 HP Briggs to shut down after only running for about 15 minutes?
Will it start rite back up?
Check to see if you have a low oil sensor,
Sometimes the oil sensor wills me it shut off when it's a little low on oil.
May 17, 2015 | Poulan Pro 19.5HP Lawn Tractor 960420123
My New Holland TC-30 tractor runs fine but when we start it, the fuel & water gauges slowly go up and finally peg, staying pegged until we shut it off.
First thing ALWAYS is to check the grounds. It's a bad ground connection on the gauges at the sending units.
Oct 28, 2014 | Cars & Trucks
2320 johne deere disiel tractor cranks over but won't start
check fuel filter first and that fuel pump works by openig at fuel pump and pushing fuel out just short of injection pump-- if no fuel pushes out prime fuel system by pushing air into fuel tank or using a in line hand fuel pump--- fill tank on tractor so that fuel is above injector pump also helps probably a prime problem
Mar 14, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John deere riding mower backfires when starting
Sounds like your cylindes are not getting gas after shutting the engine down ..this happens if the engine continues to run a little after the ignition is shut off or have too much throttle when shutting down..pumping gas into the cylinder un burned..and when you try and start the unused gas is immediately ignited coming back through the intake valves and out the carb..two things let it idle diwn as low as it can and shut it down .another is to shut the fuel shutoff valve before shutting down and let the carb gas be used up..that will not allow gas into the cylinders..just remember to turn back on fir a few seconds to refill the carb bowl before starting..good luck..
Nov 23, 2013 | Briggs & Stratton 66set Panzer Tractor...
How do you prime the fuel system so that the bulb between tank and carburetor is full
I have cleaned the carb it runs fine but will not start after it cools down(have to prime). their is a silonoid in the bottom of the bowl I think is some type of saftey shut off not sure.
Mar 20, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Skid steerer won 't start
You need to remove the fuel filters and fill them with fuel, and them if you engine is equipped with a primer,,,,prime the fuel system.
Simply filling the fuel after a run out will never start it. The system has air in it that needs to be primed out.
Aug 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
One Step Ahead New Holland Tractor Set Logo
123 people viewed this question
Top One Step Ahead Toys Experts
ray gallant
Are you an One Step Ahead Toy Expert? Answer questions, earn points and help others
